  #111
Old 02-11-2024, 02:15 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: Always having to force quit Pro Tools
Originally Posted by Thenewexhibit View Post
<snip>
On a side note; not sure if my system specs are showing (I have them filled in). I'm not sure how to have them at the end of my posts. If anyone could shed some light on that, that would be appreciated :)
Top of each forum page>User CP>Edit Signature.
(Copy your Details, paste to Signature.)
Bob
Without a song
The day would never end
  #112
Old 02-11-2024, 04:21 PM
basslik's Avatar
basslik basslik is offline
Having this same issue. I'm currently using a Samsung T7 as a bootable drive with Mac OS Monterey 12.7.3 on my Mac Trash Can 2013 and Pro Tools Studio 2023.12.1.
I haven't found anything repeatable, other than it randomly needs me to force quit more often than not. This was a fresh install of everything and everything is up to date. All of this was done probably not much more than 2-3 weeks ago. Curious to hear how this is coming along.
Yup, Edit your signature.
I also did a clean install with no 3rd party plugins and still no good.
Hopefully a fix is in the works.
As I mentioned in the past. I never had a software program behave like this.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #113
Old 02-13-2024, 12:14 PM
Thenewexhibit Thenewexhibit is offline
Thank you for the reply!
Mac Pro (Late 2013) OS 12.7.3 (Monterey)
3 GHz 8-Core Intel Xeon E5
32 GB Ram
1 TB OWC internal SSD (running off of bootable Monterey Samsung T7 test drive)
AMD FirePro D300 2 GB
Audient EVO 16 w/ two Audient EVO SP8's via ADAT
  #114
Old 02-13-2024, 12:15 PM
Thank you for the reply! I'm sorry to hear this is still happening. I pray there is a fix for it soon! It doesn't hinder any work from being done; it's just more of a nuisance and bummer than anything.
32 GB Ram
  #115
Old 02-17-2024, 05:14 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
I'm recently upgraded to a mini M1 with 2TB SSD as the 256Gb drive had become unworkable (even using several external SSDs).
I did a fresh install. I have Pro Tools 22.9.0 as I have been out of the updating loop for a while. Everything was fine, no force quits required
As I loaded my many plugins I am now back to a situation were Pro Tools requires a Force Quit because it stalls sometimes. I wonder if this is Native Instruments related as this was some of the last plugins I installed?
Also, I have a new thing of where I will quit Pro Tools and will report a crash soon after the program has quit.
I suppose it is just part of the pain of running Pro Tools, right?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #116
Old 02-17-2024, 02:08 PM
basslik's Avatar
Stephen
I tried with just stock plugins and I still have to force quit, so I'm not sure if it's your Native Instruments ?
Do you have the latest Monterey 12.7.3 ?
Duguy, has a workaround that works for some folks.
Ok guys, i found a small solution and it seems to work for me (need to test it more).
First, go to User>Shared and rename the Pro Tools folder as Pro Tools.old to generate a new one.
Like someone said, you can also check in User>Library>Logs>Avid>. It can be useful for the avid customer service.
Let me know if it fixs the problem for you too. I have also disabled avid link at launch to be sure.
  #117
Old 02-23-2024, 04:32 AM
uptown's Avatar
uptown uptown is offline
This doesn't help solve things, but for some reason, after many months of having to force PT to quit every time I want to shut down or restart, I chose to shut down my computer this morning, and it actually shut down without my having to force PT to quit.
Since then, I can quit PT and it always quits normally. I haven't updated anything or installed anything new.
MacOS 12.7.3, PT Studio 2023.12.1
Kind regards
Murray
Murray Anderson
Milestone Studios
21 Bloem Street
Cape Town 8001
South Africa
https://www.milestones.co.za
Tel: +27 (0)21-424 6000
  #118
Old 04-10-2024, 01:08 PM
Busty Busty is offline
is there any progress on this?
I, too, have this problem since uprading to Monterey, it was not present before that on Mojave.
Can't bug support about it since I'm on an unsupported setup as well as out of support plan, but I would of course still be interested in a solution.
I tried Duguy's workaround, also started without any plugins, still Protools hangs upon closing the session's audio file catalog, I'd say 100%.
In case my setup doesn't show:
iMac 2019 i9, 128 GB RAM, OSX 12.7.4, ProTools Ultimate 2023.06
  #119
Old 04-11-2024, 02:59 AM
thin ice thin ice is offline
I've gotten so used to this that I used alt/cmd/esc to quit Pro Tools without thinking. Everything else works smoothly, so best to just forget about it.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
  #120
Old 04-11-2024, 08:28 AM
tope d's Avatar
tope d tope d is offline
Hi all!
I've ran through cases with similar symptom where you have to quit Pro Tools, most are compatibility issues, systems that needs optimization https://avidtech.my.salesforce-sites...ge/Optimize-12, or third party plugins. To test, rename the plugin folder and then launch the session. Close it and then try to quit PT...
Best to create a support case and forward the logs to the tech team for further investigation if still encountering this issue.
https://avidtech.my.salesforce-sites...sh-information
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Pro Tools Crashes, Keeps Running in Background After Force Quit gabriel b. Pro Tools 11 2 01-07-2018 12:58 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 01:30 PM
Pro Tools 7 will NOT force quit... soundfx Pro Tools TDM Systems (Mac) 2 04-20-2006 03:04 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
