Old 01-19-2023, 07:34 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: New M2 Macs Out Today
Originally Posted by sdelsolray View Post
Single core performance (which is quite important in audio) is not that much different.
M2 Pro scores 1952 on Geekbench5 singlecore whereas M1 Max scores 1727. Difference of 225 is +13% so what did you expect?
Janne
Old 01-20-2023, 01:58 AM
thin ice thin ice is offline
Being as the M2 chip is still 5nm, does this mean it is just an M1 with higher clock speed? If so, can we expect fan noise in the Mini, as the M2 runs hotter?
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 01-20-2023, 03:41 AM
JFreak's Avatar
Who knows. But M1 mini with full throttle is dead silent here. And my M2 air does not even have a fan.
Janne
Old 01-20-2023, 03:59 AM
Ben Jenssen's Avatar
As far as I know, all M2's run at the same clock speed as M1s. The main differences are the number of cores, and the speed of memory addressing, and the size of memory they can use. Hence the very small difference in single-core performance between all iterations of M1/M2, and also my lack of excitement over these new mac models. My 2020 M1 has most of what I need, and I know that thousands of dollars for an upgrade just doesn't make sense. Now, the M3 by the end of the year, on the other hand… I'll be saving up…
Old 01-20-2023, 04:11 AM
JFreak's Avatar
Who remembers this supercomputer cpu called G5 from +20 year ago that was manufactured with 130nm process? Now we are going from 5 to 3... for god's sake, visible light is 380 to 700 nanometers. We need computers to build computers.
Janne
  #16
Old 01-20-2023, 06:40 AM
BScout BScout is offline
M2 = 3.48 Ghz
M1 = 3.2 Ghz
Different clock speeds
  #17
Old 01-20-2023, 06:45 AM
Originally Posted by BScout View Post
M2 = 3.48 Ghz
M1 = 3.2 Ghz
Thanks.
  #18
Old 01-20-2023, 06:51 AM
JFreak's Avatar
Who thinks clock speed is important? Intel reached 3.0GHz in 2002 but clock speed has basically remained stagnant ever since. Poor benchmark for performance.
Janne
  #19
Old 01-20-2023, 08:33 AM
Carl Lie Carl Lie is offline
All things held constant, clock speed is important. It will likely increase with the 3 nm chips.
The M2 chips seem a marginal boost over M1 but at least there is an improvement.
Can I hold out until the M3 I wonder?
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #20
Old 01-20-2023, 09:03 AM
JFreak's Avatar
Clock speed is not irrelevant. However singlecore performance boost of 13% and clock speed increase of 8% says something else is more important.
Janne
intel macs vs. slightly older macs Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2007 09:36 AM
I got my first Mac today producertravis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2006 10:29 PM
Quad Macs... released today. gomi Pro Tools TDM Systems (Mac) 34 10-21-2005 02:29 PM
New macs - today? Markk Pro Tools TDM Systems (Mac) 19 06-12-2004 08:06 AM
Got 5.1 today angelo panetta Tips & Tricks 11 03-01-2001 04:18 PM
