Old 09-29-2022, 11:32 AM
Ray Lyon Ray Lyon is offline
Default PT 2022.9 w/ OS 10.13.6 (High Sierra) on Mac 5,1
Is anyone using this configuration:
PT 2022.9 HDX w/ OS 10.13.6 (High Sierra) on Mac 5,1 (Cheesegrater)
Currently I'm running 2021.6 on HDX and everything works OK.
I know 10.13.6 is not officially supported, but it may still work. If necessary I can upgrade to Mojave 10.14... but Mac 5,1 will go no higher than that.
Old 09-29-2022, 11:38 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: PT 2022.9 w/ OS 10.13.6 (High Sierra) on Mac 5,1
Just stay where you are and plan ahead, you need new hardware soon. Mojave is listed in the compatibility chart, but marked as "untested but no expected problems". Writing is on the wall...
Janne
Old 09-29-2022, 12:58 PM
mene mene tekel upharsin (Dan. 5:26-28)
Yes, time for a new Mac soon...
Old 09-29-2022, 03:19 PM
JFreak's Avatar
I know my Bible, thank you very much
Janne
Old 09-29-2022, 03:22 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Only on 10.14.6 for me.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 09-29-2022, 06:03 PM
sdelsolray sdelsolray is offline
PT Studio 2022.7 runs fine on my 2011 iMac i5 under High Sierra (10.13.6).
PT Studio 2022.9 does not open on my 2011 iMac i5 under High Sierra (10.13.6).
Also, attempting to load 2022.9 installed a new PT helper app before it said it wouldn't run. When I tried to run 2022.7 after that, it opened but Heat would not work. I reinstalled PT 2022.7 and everything is fine again.
Old 09-29-2022, 06:36 PM
JFreak's Avatar
^^ that's why Pro Tools compatibility chart should be read like the Bible... literally!
Janne
Old 09-29-2022, 07:17 PM
Well, the PT compatibility chart nixed High Sierra quite some time ago, yet it works fine through PT 2022.7, at least for me.
I have always considered the compatibility chart to indicate what was not tested by Avid and thus "not supported". The hint that Mojave should probably work in recent releases is an example of that.
Old 09-30-2022, 07:50 AM
I need to update my bible to the King Louis edition to get Cloud access, but sadly my original subscriptsin has expired.
Sorry if this is in poor taste, but I couldn't help myself.
Scott Gatteño
Old 09-30-2022, 01:03 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Well, it’s working well on a 5,1 metal Mac Pro 12 core.
HDX in Hybrid mode for new Aux-bridging!
10.14.6 Mojave.
Mel-studio 5.3
Compatibilidad de Pt 2022 con High sierra Boca_starr Pro Tools 5 06-15-2022 03:09 AM
OSX high sierra Converted202 macOS 3 09-13-2019 04:18 AM
How can I get High Sierra 10.13.6? SteveGarman macOS 6 08-04-2019 09:33 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
