Source Connect 5.1 - WOW!
Last night I very successfully connected to Vintage King LA for the groundbreaking public demo of Source-Elements plug in "Source Connect 5.1"
We were successfully streaming 5.1 audio at 125Kbsec AAC (what you have been buying on itunes) per mono channel. Our buffers were set at 10ms so communication was instantaneous (well that's 1/4 of a pal frame to you and me). I was controlling the session and Pro Res pictures in LA via remote transport sync and they were hearing my audio accurate to within 8 samples (I believe). We also were also screen sharing so that I could show how I was muting the various stems in real time so we could show that it was a LIVE event and stream and not a set up. In between running the promo demo session in 5.1 I was streaming some stereo music upmixed to 5.1 with TC unwrap. This is groundbreaking and very exciting for us post folk who work in 5.1. I dread to think what the isdn costs would have been for the 2hour link up (x six channels x 2 lines). The plug is still in Beta testing, so watch this space... cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Re: Source Connect 5.1 - WOW!
What was your Internet connection? Ethernet over Copper (EoC)? Fiber? Was it the same ISP all the way between point A and point B?
HI Jonathan
Different ISP (mine is a UK only supplier - Virgin) I have fiber 5Mb Up / 125Mb down, no idea about the other end. I had enough bandwidth to send the 160KBsec full monty but I am not sure if the end had enough - we never tested further I had skype open as well in case it suffered any beta issues. cheers
Those speeds are far beyond anything I can afford at my place. NYC is not a friendly place for guaranteed upload speeds.
We do a lot of hook ups for reviews of shows between Canada, L.A and Dublin. We do it via Isdn and just decode the LtRt. Would be interested to see how stable this is so that we could actually use the discrete 5.1. I guess it really is down to everyone's ip. So are the source connect/pro tools HD issues sorted?
Could you please be more specific?
I've been using SC standard as RTAS with mixed results over the years. Now we are on Fibre (20mbps up and down) I am giving the SC Pro standalone a serious test with an upcoming blockbuster ADR session. I am hoping it won't make me reach for my ISDN box.
I see. Our only hope for that to be resolved is with AAX. We will find out when AVID ships a version of Pro Tools without RTAS and TDM if AAX resolves those issues.
Nutmeg runs Source-Connect as a standalone application on an iMac11,2 equipped with 16GB of RAM using a ProFire Lightbridge interface connected to a Rosetta 200. When we have to use RTS, we still use Source-Connect as a standalone application and use Pro Tools v10.3.4 to ReWire the time code into the app. This works if we are driving (time code master), as we have a JL Cooper PPS LTC-->MTC converter. If the other facility insists on being the time code master, then we run it as an RTAS plug-in in the control room. That's where these issues creep up. Usually a quick stop/play toggle cures it until it happens again.
Curious, why run it as a standalone on a separate computer? Stability? Ram allocation? So far, no troubles running it as a standalone on the same computer here.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Source Connect LA | BobbyDazzler | General Discussion | 0 | 10-27-2013 03:52 PM |
10.3.5 + Source Connect Bug | ChrisMac | Post - Surround - Video | 5 | 05-17-2013 10:49 AM |
Source Connect NYC | MIKEROPHONICS | Post - Surround - Video | 4 | 08-23-2011 05:39 AM |
Source ZIP- a new nifty utility from those Source Connect People | MIKEROPHONICS | Pro Tools TDM Systems (Mac) | 0 | 01-13-2010 09:05 AM |
source-elements.com/Source-Connect | clusterer | Pro Tools TDM Systems (Mac) | 3 | 10-30-2005 05:16 AM |
