Old 07-12-2012, 02:49 PM
RuffinMedia RuffinMedia is offline
Default Offset frames count for 59:58:00
How do I offset the frame to start at 59:58 so at 1:00:00:00, the frame count will be at 0? Currently, my session says 3+00 at 1:00:00:00 when it should read 0+00.
Mac Mini 2.5 GHz Dual-Core Intel Core i5 - 16gb Mem - MacOS Catalina 10.15.5 - Pro Tools 2020.3.0
Old 07-12-2012, 03:21 PM
C C is offline
Default Re: Offset frames count for 59:58:00
Setup->Current Feet+Frames Position
Park yourself at 01:00:00:00 then use this menu item.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 07-12-2012, 08:46 PM
JKD99 JKD99 is offline
That will obviously work, but it's a bit of an odd request.
If you're using Feet and Frames, then 0+00 is always at the hour mark but then 59:58:00 doesn't usually mean anything....not like it does in video projects where the 2-pop is at 59:58:00, and the FFOA is at 1:00:00:00
In a 35mm film project the Picture Start Mark (the head of the leader) is at 0+00, the pop at 9+00 and the FFOA at 12+00. Timecodes for these would be 1:00:00:00, 1:00:06:00 and 1:00:08:00 respectively. So 59:58:00 would actually be -3+00
Or, I'm just misunderstanding and you have a perfectly valid reason for your question and in which case Ceri's answer is spot-on :)
Best,
Joe
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
HTML code is On
negative feet.frames offset? is it even possible? sndgeek Post - Surround - Video 7 06-20-2004 11:27 PM
dropped frames with white flash frames Frank Kruse Post - Surround - Video 6 05-08-2003 10:57 AM
Echofire latency / Offset frames (ms) ?? tomas_weber Post - Surround - Video 1 01-02-2003 03:04 PM
CD Offset Frames dBgogogo Digidesign Hardware & Software 1 09-11-2002 01:42 PM
Nudging in frames, 1/4 frames and sub frames in PT 5.1.1 LE psax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-27-2001 10:43 PM
