Old 06-14-2006, 03:00 PM
joe doc joe doc is offline
Default Help! Problems with Reason Adapted 3.0.5
Hello
When I try to run Reason Adapted on my Mac Book Pro (dual 2 GHz, 1 gig RAM - MBox2, PTLE) I get the following message:
" Failed to locate and install Reason Engine, exiting "
Digi support said that I should re-download (maybe corrupted download) but I have several timesand the file comes through without a hitch. There is some sort of setting or trick Im missing, and I have been searching all day.
Has anyone else had/solved this problem? Please help!
Thanks!
Routing problems with Reason Adapted in PT LE 7.4.2 AdamKurutz Virtual Instruments 1 10-18-2008 01:55 PM
REASON ADAPTED 2.5 & REWIRE PROBLEMS ***BBOY*** 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-10-2005 12:19 PM
Reason 2.5 adapted problems again sil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2005 04:22 PM
Problems using Reason Adapted bigdave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-31-2005 02:59 PM
Problems with Reason Adapted Aussie Scott 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-16-2005 02:32 AM
