Old 12-19-2022, 01:50 PM
DigitalVortex DigitalVortex is offline
Default Grid vary sporadically and unintentionally
One more amateurish question from the series "Has been disturbing since forever".
Please check the attached pics.
Is this some kind of anomaly/bug, or is it a result of any action of mine?
These ****s appear out of nowhere and seams not to be only a screen/zoom-in problem that is easy solved by changing the zoom level.
I don't know if this is purely grid related, or if it could (also) be tempo related somehow. I have several tempo changes in the songs. I don't use any tempo operation windows etc, only the green tempo bar at the top of the screen. Also, I never work in the dedicated Midi Editor window since I hate it, so I work only in the main window, but in Edit mode. The Conductor is "On".
Old 12-19-2022, 02:58 PM
Ben Jenssen's Avatar
Default Re: Grid vary sporadically and unintentionally
Check the Meter ruler. A change from 4/4 to 3/4 will cause a bar to change size. Any meter changes happening?
Old 12-19-2022, 03:20 PM
You rule Ben! It absolute solved this old misery. Thanx a lot!
And yes, it emerged that there were a LOT of meter inserts, that I never put there in the first place btw. Strange thing is that all of them were 4/4, so no variation at all. Although, I sense that it's not only about what value you insert, but also where. So if a value is inserted in an "illogical" place – like just in the middle of somewhere – it adds a rhythm data from that very point and in consequence also adds a visual grid data.
Old 12-19-2022, 03:23 PM
Glad I could help.
Edit Mode difference between: Grid and Slip+Snap to Grid zenstone macOS 0 02-05-2015 04:34 AM
When loop is TCE'd to grid then duplicated out, it doesn't match the grid. STSCRUSHER Windows 1 11-23-2012 09:34 AM
Please help! Signal from Instrument Track appears in Aux/Audio Tracks unintentionally JimDC macOS 2 05-07-2012 09:02 AM
Slip to Grid mode no visual grid unless pressing "grid" mgoorevich Pro Tools 9 5 11-13-2010 07:11 AM
Link Grid Mode w/Grid display in PT8.0.3? pugzillas Pro Tools TDM Systems (Mac) 7 03-19-2010 03:44 PM
