Session Cutter
Hi
Is anyone using this? How do you like it? Does it read AVID edls? - I'm looking for something that will auto conform an existing session to an edl. In other words making change notes happen then showing me where it made changes so I can smooth or ignore them... thanks scott
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news. |
Re: Session Cutter
Hi Scott
It doesn't work that way, unfortunately. I've got it, and I can't honestly figure out what the advantage is over just making the changes in your session with Avid change notes. However, rebalances are MUCH easier. But only in time code? No feet and frames? I thought it was designed for use in film.... ------------------ Joe Milner Puget Sound Los Angeles |
Re: Session Cutter
scott
Re: Session Cutter
try titan from www.synchroarts.co.uk. Full edl conform and flash conform from SD II media.
Re: Session Cutter
thank you OB - I will check them out asap.
Re: Session Cutter
Hello obelointment,
Do you use Titan. Could U give us a quick assessement. Especially for re-conforming regions (and hopefully) automation too... TIA |
Re: Session Cutter
Mix
I am testing Titan now. I will post back. The Titan folks are super responsive. We are in the middle of a gigantic conform/re-balance and the re-balance really chokes it all. we have to be ready by Monday. I haven't had luck YET - but as soon as i have time I will back test this on a version BEFORE re-balance. Conclusion: nada yet. Looks promising. they have a working demo you can download. scott
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Session layout not being remembered after closing/reopening a session/Pro Tools! | DJ Hellfire | Pro Tools 10 | 1 | 12-23-2011 12:05 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
