TRacks
It has come to this. I cannot afford any of the WAVES products (they suck lots of processing anyway). I also cannot afford Mastering fees.
So, I may check out TRacks. Is anyone using it? I assume you just load up the .wav file to it, process, save, then burn on CD? ufo |
Re: TRacks
I love t-racks. It's not a plug in. But it's intended as a final treatment although you can use it for so much more. It will take your 16 or 24 bit wave files and dither it for your CD or other master. I use it to treat acoustic drums and then insert back into protools. Best of all it's simple to use and has a lot of great presets.
Re: TRacks
i use it. Like the previous reply, i find you can use it for much more than mastering. The presets are also pretty incredible
Re: TRacks
I guess this is a silly question..but, since t-racks is a seperate app, how do I monitor what it is doing? Thus far, I monitor everything through the 001.
ufo |
Re: TRacks
You can hear it through your Digi001, at least I do..
-KD |
Re: TRacks
If you need to monitor through the digi, you should be able to. If you have 2 sound cards in your computer (ex: sblive and digi), it might use the reg sound card by default. Most applications have preferences to choose which sound card you want. I don't have T racks, but I use cool edit to do some cleanup after I'm done mixing. Works the same way.
Has anyone used both wavs and t racks? I have Wavs and it's great but a lot of people use t racks so I'm wondering if I should switch. [ August 30, 2001: Message edited by: executivos ] |
Re: TRacks
I've used T-racks quite a bit, and found myself using it to 'pre-master' (no limiting) and still using soundforge with the waves L1. I've never heard anything yet that's even close to the L1. I did really like the way T-racks' EQ and Compression worked though. The dithering is good too. I really don't like mastering in Pro tools. If you ask me, DIGI needs to make a two track version of Pro tools that is basically a super rip-off of the SoundForge/CD Architect setup. I think that would sell so fast, and set a new standard for mastering. I love the way those programs work.
Mike Blanchard Engineer |
PT10: Import tracks with overlay+match tracks not working | Frank Kruse | Post - Surround - Video | 3 | 12-02-2011 09:06 AM |
OPEN WITH TRACKS INACTIVE???---snow leopard is biting my foot (& tracks) | stormmusic | Post - Surround - Video | 2 | 10-09-2009 04:43 PM |
Instrument tracks VS Aux tracks+MIDI tracks | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2006 04:08 PM |
How many Megs does a 4 minute song with maybe 3 stereo tracks/13 mono tracks take up? | Sergeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-04-2002 02:31 PM |
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2000 08:40 AM |
