PT12 4K monitor vs new imac 27 vs nMP
Hey all,
I want more real estate on my screen (for PT and plugins) but not all the time. I ventured into a Mac store and checked out the Retina 27" imac. Love that screen and the scaling for standard apps looked amazing! So I have a 2013 nMP and would love to do a 32" 4K solution if it worked anywhere near as well. Anyone have some experience to share? Is the imac the only great solution for 4K/5K on macs??
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Re: PT12 4K monitor vs new imac 27 vs nMP
I am interested in 4K as well, but I must say I am completely happy with my 1080P LED TV as my main screen.
I've been using this for a few months now, and I think its brilliant.
http://www.philips.co.uk/c-p/BDM4065...it-lcd-display My second monitor is an Apple Cinema display 30" And yes, I'm using a Mac Pro (2013), and it works wonders ... |
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Well, depends on the desk I would say ... Quote:
I've had no issues in PT 11HD with this one ... none ! And if you need a little bigger text working late at night, pick the (lower) resolution you prefer. Really no big deal ... I usually work in 3200 x 1800, but I might do the 3840 x 2160 if details are not important. I am using Yosemite, Pro Tools 11HD 11.3.2, running the monitor at 60 Hz. G Last edited by Gemylon; 10-16-2015 at 03:22 AM. |
For timeline based applications (such as Pro Tools, Logic, Final Cut, etc), have you thought about an Ultrawide monitor? I currently have an LG 34UM95-P Thunderbolt display hooked up to my nMP and the screen real estate is amazing. I can see SO much more of the Edit and Mix windows. It runs at 3440x1440, so it ends up being the same size height-wise and resolution as a 27" 2560x1440 monitor (like the Apple Thunderbolt Display), just with a bit extra room on the left and right.
I don't imagine working at 4K or even 5K would yield the same screen real estate (although they'd look sharper obviously) Check it out! |
I've been testing out 4k monitors with the trashcan macpro and I'm having lots of problems... are you on Mavericks or Yosemite? I think most of my issues have to do with Mavericks... planning on upgrading a clone to test soon. evidently Mac OS has some bad 4k drivers that don't allow proper functionally at 60hz... and many times res will default to 30 which you will feel as a lag. check out the apple forums to see what issues people are having. forcing the rate to 60hz through tools like switchResX will sort of work but causes various anomalies. :-/
+1 for using an LG UM95, 34" diagonal running 3440x1440.
I ended up going this route after discovering that I wouldn't be able to find an adequate acoustic compromise with a 4K display. It's simply so much resolution that to make use of it you need to be very close to it, and they are taller than an ultra wide 21:9 monitor, getting more in the way of my listening triangle. 21:9 becomes pretty addicting once you've gotten a taste of it, and you can fit a LOT on 3440x1440 while keeping it relatively out of the way, acoustically speaking. When mixing, I keep the display just below the base of my speakers and slightly angled, finding a sweet spot between acoustics and ergonomics. An adjustable height desk is helpful for this. |
Input Monitor Status Indicator missing in PT12 | faderdominator | Pro Tools 12 | 20 | 06-30-2015 02:50 PM |
PT12 input monitor? | tomorrowstk | Pro Tools 12 | 7 | 03-25-2015 04:28 PM |
Using 2nd Imac for 2nd screen monitor | K Roche | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-09-2009 06:23 PM |
Dual monitor on iBook, eMac, iMac | JC925602 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-04-2004 06:54 PM |
M-Box with iMac G4 800 mhz 17" monitor | lynxxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-22-2002 12:03 AM |
