Put the MIX knob halfway.
BTW, if you look at the top of this and every DUC page, you will find some helpful hints, including: Please post your message once only to the correct forum asking the same thing over and over doesn't do anybody any good.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
I have been, and I'm getting nothing. There's also an occasional popping sound. Any more ideas?
You said you installed PT8 on a new laptop.
Are you shure you didn't install on a too new, incompatible OS version? |
![]() Quote:
the last Mac OS version LE8 officially was supported with was Mac OS 10.6.8! A few people obviously could use it with later OS versions too but most of them were not able to get it work with 10.9. anymore. There are lots of entries here at the DUC telling about this. As you probably won´t install 10.6.8. on your new Mac (which neither will be possible actually) you rather will have to upgrade to PT11 or change to Logic X (which also may work with your MBox 2). It depends on how much money you may be able to spend for it. No hard feelings because of my Logic suggestion, it´s just an option if upgrading to PT11 would be too expensive at the moment and you would want to keep the MBox 2 and keep recording music now. However wishing you the best, cheers, VRW MacMini i7Quad, 16GB Ram, MBP Mid 2012 i5, 16GB Ram, MacOS 10.9.1, Apogee Quartet+Duet 2, Genelec Active, Yamaha NS10, Pro Tools 11.1.2, Logic 10.0.6, Waves, MCDSP, Duende Native, Softube, HOFA, IK Multimedia etc |
Are you sending the tracks to a main master fader? Where is sound being sent to is where I would start- check you tube for setting up master fader if you're not familiar- hope this is helpful.
#16
Did you end up solving this? I have the same problem. I can hear the playback in the headphones, but not the record track, although I have full input signal and record just fine. Just can't hear it as I play. Weird.
Pro Tools LE8 No Input Signal? | RyanChappell1987 | macOS | 14 | 01-18-2014 08:33 AM |
No Input Signal - Mbox 2 - Pro Tools 8.0.5 | davemeasom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-27-2012 05:42 PM |
Is my computer strong enough to run pro tools le | konnekt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-12-2011 10:50 PM |
Fast Track Pro Outputting Mic input to Monitor, but Pro Tools 8 shows no mic signal | changa86 | Pro Tools M-Powered (Mac) | 3 | 12-18-2009 11:06 PM |
Input signal, no sound | jasdell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-01-2009 01:48 AM |
