6.1 ok but wave and ASIO not working!
So I installed 6.1. It works great, but I couldnīt figure out, how to get the wavedriver work. I installed the 6.1 beta wavedriver, but I canīt get it to work with the Reason Demo. In its audio (and MIDI also) preferences there is no option to select, just "no audio" and "no MIDI". And the ASIO driver does not work with Wavelab! So whatīs the solution? Has anyone similar problems and has found the solution?
Thanks in advance
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: 6.1 ok but wave and ASIO not working!
WaveLab (version 4.0.1a or whatever) with Digi ASIO for 001 works fine for me, though ironically, PT 6.1 doesn't (check my numerous posts about BOUNCE TO DISK [img]images/icons/wink.gif[/img] ).
one of the Digi paper book things that come with 6.1 says not to install both the wavedriver and asio on the same computer.
you cannot find peace by avoiding life |
I did nor install both drivers the same time!
what version of WaveLab?
4.0g
But Reason Demo ainīt working in standalone mode also! Just silence. In ProTools everything works ok (didnīt bounce yet [img]images/icons/wink.gif[/img] )
claus -
Are you trying to use wavedriver, or are you trying to use ASIO? With Digi 002, I've used the 5.3 ASIO driver with Reason demo, 2.0 and 2.5. I've used the 6.1 ASIO driver with Reason 2.5 . All worked well for me. The Digi ASIO driver doesn't support MIDI, so I used my Soundblaster for that.
Quad 2.5 G5, 4.5G RAM |
Iīm trying to use the wavedriver, as long the ASIO driver will not be recognized by Wavelab. But the new beta wavedriver will not be shown in WL...
...so both drivers wonīt work for me...
WAVE and ASIO at the same time? | Jerry K. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-07-2005 03:02 PM |
Wave or ASIO driver | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-25-2004 07:47 AM |
Wave & ASIO 6.1.1 | JMS40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-24-2004 01:51 PM |
Good\Bad - ASIO\WAVE | BimDimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-17-2003 08:06 AM |
ASIO or Wave Driver | Jerry K. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-09-2003 07:15 AM |
