hardware setup preferences with Logic (again)
this should be easy but it doesn't seem to be. I have been previously told on here that the way to get Logic to automatically revert to a saved hardware setup, is to trash the 'digisetup' preference and start again. I have tried this and Logic will still not revert to the saved settings
any suggestions??- thanks [img]images/icons/frown.gif[/img] |
Re: hardware setup preferences with Logic (again)
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR> this should be easy but it doesn't seem to be. I have been previously told on here that the way to get Logic to automatically revert to a saved hardware setup, is to trash the 'digisetup' preference and start again. I have tried this and Logic will still not revert to the saved settings
any suggestions??- thanks <HR></BLOCKQUOTE> this is the wrong way round, unfortunately. The set up info for your hardware is saved IN the digisetup file. trashing it will give you a default hardware setup. If you still have the old digisetup file, you can revert to your previous setup by dragging it into the prefs folder. If not, you'll have to reset it manually, in the audio hardware dialog of the audio window. Malcolm |
i didnt read your first post !!! so maybe i am saying something similiar youve been told already .
just choose the settings you want to have ( harware , keysettings , channel setup , environment etc. ) and simply save it as f.ex. " autostart X " . anytime you launch logic via the saved " autostart X " file the settings youve choosen appear . dont start logic with the program icon itself . it will always start up with unmodified arrange windows and setups . mayB that helps ??? |
Hardware preferences won't save | radkins | macOS | 0 | 05-31-2013 09:06 PM |
003 is not in the hardware list in mac sound system preferences. | ritualbeatingsystem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-08-2009 03:16 AM |
Pro Tools keyboard with Logic preferences? | ianmiller | Pro Tools TDM Systems (Mac) | 1 | 01-17-2008 06:40 PM |
I/O setup doesn't reflect my hardware setup | devapro | Pro Tools TDM Systems (Mac) | 7 | 12-30-2006 11:16 AM |
SSD setup preferences | SOR | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 06:45 AM |
