Old 08-13-2007, 08:17 AM
ajazzie ajazzie is offline
Default Turn it off or leave it on?? C24
I have just built a console for th C24 and access to the on/off switch is a bit of a pain.
How long do you guys leave it on for, when its in built in consoles I imagine that this has been a quetion asked before?
AJ
A Gentleman is one who can play the bagpipes, yet chooses not to.
Old 08-14-2007, 03:03 PM
Mario C Mario C is offline
Default Re: Turn it off or leave it on?? C24
Ours is powered through the main power conditioner in the room. When the room is turned off, the C24 is turned off also.
But for your question, we power it off every night. Some will argue against that I'm sure, but it's not been an issue with us.
Mario C
Metcom Studios
www.metcomstudios.com
Old 09-15-2007, 11:22 AM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Hey. Maybe a stupid question.....
I always thaught it was bad to have Phantom Power on when power cycling (on/off)
Do you guys leave it on? Or turn it on and off as you need it.
I can't imagine leaving it on ALL THE TIME, as I'm sure it'd be bad for the pre's?
I just figured it'd spike on cycling.... maybe not.
As far as leaving the C24 (or its pre's) on all the time. I too have the power set to ON and cycle it with my conditioners. My tidbit to not leaving it on is this: Solder actually grows hairs- it's a fact. Over time it grows microscopic hairs..... and as we all know, the circuitry on these things is very fine and close in some places, in which case it can eventually short. or whatever.
could be bad news.
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 09-15-2007, 01:41 PM
netnoggin netnoggin is offline
Seems as though the whiskering effect is more of a problem with RoHS-compliant gear, and I'm not sure the C24 actually is RoHS compliant. Nevertheless, I don't think it's impacted by whether or not the power is on. I could be wrong.
Here's a basic blurb on the hair problem, for those of you not up to speed on the subject: Radstone.RG06.pdf
Look around the middle of page 2.
Another reason it may not be a problem on the C24 is it tends to only affect very closely-spaced circuit traces, and the internal boards on the C24 are not exactly using micro-miniature technology. I had to open mine up to repair one of the sliders because it got beat up in shipping. Repair was successful, and it gave me an opportunity to sniff around the insides while I had it open. Let's just say the board layouts are consistent with the time period the C24 was originally designed, which has been a while ago.
At any rate, I'm not real regular about leaving on or turning off. I definitely power down the whole works if bad weather is eminent, but I do like to leave things running so I don't have to make a big deal about going in to lay down some tracks. Sometimes creativity doesn't want to wait. I do know I turned the C24 off before turning the monitors off just once. Won't ever do that again; the thump almost threw my monitors' cones into the next county, and sent the cat four feet into the air.
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Can't turn off Mac Function keys/turn on PTLE Shortcut keys b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-25-2009 09:15 PM
turn off or leave on? soundguydave Post - Surround - Video 12 10-27-2006 08:14 AM
i-lok- Leave it on or turn it off? tedro Pro Tools TDM Systems (Mac) 7 06-06-2006 11:21 AM
002R - Leave on or turn off... RCAinTN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-30-2006 09:37 PM
g5mac leave it on or turn it off workhouse Pro Tools TDM Systems (Mac) 1 02-15-2005 02:05 PM
