Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-22-2023, 06:59 PM
Dbtoys Dbtoys is offline
Default Api lunch Box in to Carbon.
Hi I just hooked up my new carbon interface
Using the api 512 c’s in a lunch box
From the api’s I went from xlr to 1/4 inch in on the back of the carbon.
My question is do I need to configure the carbon any diff to disable the carbon mic pre’s? Or any thing else?
I have looked for this info and could not find it anywhere.
Old 01-23-2023, 04:44 AM
dominicperry dominicperry is offline
Default Re: Api lunch Box in to Carbon.
You might want to refer to this recent, relatively short thread:
https://duc.avid.com/showthread.php?t=423198
or the manual.
Yes, from the lunchbox to the Carbon, you should use the jack inputs. TRS (i.e. balanced) is preferred to TS (i.e. unbalanced). You cannot use the XLR's for line-level input, only the jacks (or the DB-25).
You can leave the line-levels as variable input gain, or change them in the Carbon setup page to fixed (shown in post#4 in the thread above).
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 01-23-2023, 08:25 AM
Thanks, that clears up a whole ton of questions I had.
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
Pro Tools 11 will not lunch on my MAC , Help akhafaji macOS 2 09-03-2013 11:21 AM
Can't lunch Pro Tools Choral14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-02-2008 01:15 PM
PT LE won't lunch RicardoEscallon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-04-2000 04:21 PM
