2560 x 1080 Resolution for PT/Windows 11?
Hey guys,
I just bought a 1913900k (not yet installed) for use with Windows 11 and PT 2022.12. I was thinking of purchasing a 2560 x 1080 res wide-screen monitor to replace the two 23" monitors I'm currently using. Will it work well? Will both the edit and mixer windows show correctly and comfortably without useless extra space on the sides? I currently don't use a dedicated graphics card; I use the processor graphics for video. Thanks in advance for any useful insight.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Re: 2560 x 1080 Resolution for PT/Windows 11?
I can't answer your question directly, but I have a very wide 32:9 monitor (49" corner to corner, which is about 45" x 13") and resolution is 5120x1440. That makes everything too small, so I have to use 3840x1080. And 1080 is not enough pixels high to get everything that I want to see in a PT mixer on the screen.
So I wish I'd bought something physically taller than 13" with more than 1080 pixels. My point is - it's not just the resolution, but the size of the screen that matters, especially once you start needing reading glasses. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Thanks EGS. Just curious, how do you use your 3 monitors?
LB
Have you considered a 65" 4K TV ? As long as you can drive it at 60Hz its pretty good. I mounted mine on the studio wall. I went with LG. It's like 2 stacked ultrawide monitors. And you can adjust the scaling in Win 11 so that you can see details from anywhere in the studio depending on where you are working. ejinbc |
Mic Pres (I have a Carbon) HEAT Inserts A-E Sends A-E EQ Curve Meters and Faders I/O Delay Compensation Track Color Comments and it's just too much. I have to scroll or uncheck 2 or 3 of the options to keep it all on-screen. Dominic
43" in the center = Pro Tools Edit window. This tends to keep my ears centered in the sweet spot between monitor speakers. I usually face the edit screen, so when I work at studios with only 2 screens, I skew my ears to one side... It's better with the Edit Screen dead center. My opinion.
23" to the right - Mix 23" to the left - plugs/video/misc I run all 3 @ 1080P. Works!
Как перейти с PRO Tools LE 8 на PRO Tools 10 или 11? | olegprozetov | Windows | 1 | 08-24-2013 12:05 AM |
midi set up 1080 | Fabulous | MIDI | 0 | 10-22-2012 01:00 AM |
Using Roland JV-1080 through 11R | Tony-N | Eleven Rack | 1 | 02-18-2012 11:28 AM |
JV-1080 or JV-2080, which is better to go for...?? | AppleFunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-26-2004 11:40 PM |
JV 1080 | scarlip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-01-2002 01:11 AM |
