Reorder memory locations
I know it's a long shot, but is there a quick way to reorder memory locations? For example I have 45 laid out for scene changes, then added two in the middle, is there a way to reset all of the numbers so they're remade sequentially, rather than going through every one and changing its number?
cheers |
Re: Reorder memory locations
It seems to me that I remember being able to renumber markers back in the earlier TDM versions. Could be remembering wrong. If so, that feature was removed at some point, probably when memory locations took on a slew of extra (and very convenient) non-temporal features, such as recalling track heights/show-hide, window configs, etc.
There is a way to insert markers, and to delete them in such a way that the following ones renumber. That's all explained on p. 802 of the Reference Guide. It's probably your best workaround, unless you can live with simply sorting them by time (where the numbers are out of order but the markers are displayed chronologically).
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Aaron Mulqueen - 001 HD Native |
EdiMarker converts MIDI files containing Pro Tools markers into text files and vice versa. It provides sound editors with a streamlined way of extracting marker data from a session or creating Pro Tools markers from a list of names and locations. EdiMarker can also be used to transfer markers between Pro Tools and Nuendo. Available for OS X and Windows, the program is licensed as donationware.
http://www.soundsinsync.com/products/edimarker There is some discussion about the App here; http://www.gearslutz.com/board/post-...x-windows.html I'm only assuming (because I haven't used it) that once markers are exported to text they can be edited then imported back into session and that they can be used not just for Midi files. If they do only work with Midi files there maybe a workaround to get the required solution. Anyway, it's worth a look, I hope it works for you.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
You can do this in protools. Insert marker before somethingor other. Not in front of my rig. It's in the little marker window. Command+5
Ah yep, in the memory locations window dropdown menu there's 'Insert slot before ...' which pushes all the numbers back, thanks all.
It'd be cool if there was a shortcut for this, or a preference for it to automatically do it, or an option to reorder them after they're all made. Anyway, this'll save a lot of time! cheers |
More memory locations? | BothMan | Post - Surround - Video | 1 | 11-15-2002 02:41 PM |
Memory Locations | Wee Gee | Pro Tools TDM Systems (Win) | 0 | 10-04-2002 03:48 AM |
Memory Locations | Fave | Pro Tools TDM Systems (Mac) | 2 | 04-05-2002 05:01 AM |
Memory Locations in PT5.1 | Brent Burge | Pro Tools TDM Systems (Mac) | 0 | 04-07-2001 04:02 PM |
Memory Locations | Rams Boy | Tips & Tricks | 1 | 03-07-2000 03:10 PM |
