Old 11-10-2010, 11:39 AM
randori randori is offline
Default Axiom Pro 49 with PT 8.0.3 LE
Hello Forum!
I bought this Axiom not only for controlling PlugIns but also for fader adjustments etc. with the pt-mixer. I saw some of those promotion/information videos and was very impressed of the functionality...
But I can not do the same things... (ok, I have to learn and try, but maybe there are some tricks)
The PlugIns like Hybrid, vacuum, etc work very good with the Axiom but I have got some questions:
1) Is there a detailed description of hypercontrol and how it works with my pro tools? Or an in deep instruction for the Axiom pro?
2) I want to remote the PT-Mixer with the Axiom. How does that work?
3) PlugIns like the EQs do not have the Learn Function I have seen in the videos. Is this only working with the pro tools HD? If this is the case, why dont they tell it in the video?
4) On the MIDI-Contollers (Peripherals dialog) I can´t choose the Axiom. Why?
Thank you,
randori
Old 11-10-2010, 03:44 PM
frantik frantik is offline
Default Re: Axiom Pro 49 with PT 8.0.3 LE
not really.. just the manual
what do you mean? the sliders should move on the PT mixer when you're in hypercontrol mode
it sounds like you don't have it installed properly or something. did you install the drivers? you will see the 'learn' functions when you do have a controller enabled.. same with the slider functality
Trikome.com - blog
PTMP 8.0.1 // FLStudio 9 // WinXP SP3 // Axiom Pro 49 // Delta 44 // Mackie HR624 // AKG K701 // Emu 6400 Classic
Old 11-10-2010, 11:53 PM
/what do you mean? the sliders should move on the PT mixer when you're in hypercontrol mode/
Do I have to enable hypercontrol mode? I thought it was built in PT8. So how can I do this?
/it sounds like you don't have it installed properly or something. did you install the drivers? you will see the 'learn' functions when you do have a controller enabled.. same with the slider functality /
I am not able to enable a controller (see 4))
Thank you,
randori
Old 11-11-2010, 09:38 AM
Supplied with the Axiom Pro is a HyperControl Guide, this guide will instruct you on how to configure Axiom Pro and Pro Tools.
Aaron Mulqueen - 001 HD Native
Old 11-13-2010, 03:59 AM
From the guide:
Once the installation is complete, launch Pro Tools 3. Select “Peripherals...” from the Setup menu 4. Select the “MIDI Controllers” tab from the window that appears 5. Click the first “Type” drop-down menu and select “M-Audio Keyboard”
This is what I meant with 4).
I can`t choose anything in this menu!
Maybe an installation mistake by me, but how can I fix this?
Thank you,
Randori
Old 11-13-2010, 03:40 PM
You wouldn't happen to be running a Mac? Does any of this apply?
Axiom 49 Help!!!! Versa MIDI 0 09-18-2012 03:32 PM
Axiom pro 61 - should I get it? johndavid MIDI 7 07-08-2011 02:10 PM
Axiom Pro 49 and Axiom 61, Prepheral issue? udhoshi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-22-2011 03:45 PM
Axiom 61 2nd gen davidlustrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-04-2010 09:29 AM
Axiom Pro 49 vs Axiom 49 JonnyGinese MIDI 13 09-18-2009 06:33 AM
