Old 12-15-2011, 01:01 PM
Limn Limn is offline
Default Pro Tools M-Powered 8 wont install on my Windows 7 laptop
Really it's like the computer doesn't even want to read the disc. Takes forever for the autorun to come up, then just freezes when it tries to install. If I do get an error message it says the setup file is not a valid win32 app.
The disc itself just says XP/Vista, I bought it a little over 2 years ago...I think Windows 7 had just come out. I just downloaded all the updates, Im on 64-bit SP1 Windows 7.
PLEASE HELP
Old 12-16-2011, 12:14 PM
Exclamation Re: Pro Tools M-Powered 8 wont install on my Windows 7 laptop
Should I mention that everything else works fine on this computer, its not even a year old, never had any installation issues with anything.
The Pro Tools installed fine on my Vista machine...but on the Windows 7 it just does nothing.
Yesterday I got it to actually start installing, but the bar never moved. I had it sitting, plugged in and no screen saver/shut off to interrupt it, literally for 24hours doing the install and it never did anything.
PLEASE offer some help. Don't tell me to upgrade to PT10 right now, because I already have to pay $60 to replace my iLok so another couple hundred to upgrade to the new version of this, just to have more headaches like this doesn't seem very logical; when I can go to Sonar for under $200.
Old 12-20-2011, 06:40 PM
Default Re: Pro Tools M-Powered 8 wont install on my Windows 7 laptop
nothing?
Old 12-20-2011, 07:48 PM
necjamc necjamc is offline
Default
If you have registered the software check your Avid account for a full installer of 8.0.5 (I think) which is comparable with windows 7. This will eliminate the DVD all together.
Old 12-21-2011, 03:04 PM
ronaldcetto ronaldcetto is offline
Had basicaly the same problem because I'm running win 7 SP1 64bit with a Quad-4 procecssor and upgraded it to 8GB RAM 640GB HD. I took my computer to the Music Store that I purchase Pro Tools. They can installed the program for me from AVID because they are a dealer. There was nothing wrong with my disk. Things sometime just happen witk bytes. Now I'm all excited about using this DAW since I'm new to it and this forum. hope this helps you.
Old 12-21-2011, 08:05 PM
Default
Actually there were reported problems with some pro tools disks in the past I believe with version 8.
Old 12-25-2011, 05:00 PM
Disc is fine, installed on my Vista machine with no issues. And has installed in the past on XP no problem.
Ill take it back to Guitar Center tomorrow to see if they can install it, but they're usually idiots.
I could've sworn I registered it (cant see why I wouldnt with this program) - but Avid doesnt recognize me so I guess Ill hope for the store-fix.
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
Windows Laptop for Pro Tools M-Powered travgei General Discussion 11 06-11-2011 03:55 PM
Pro Tools 8.0.3 M powered Wont install! mrstark Pro Tools M-Powered (Mac) 10 11-30-2010 11:01 AM
Can't install Pro-Tools M-Powered on Windows 7 wengnutt Pro Tools M-Powered (Win) 7 04-16-2010 09:18 PM
Pro Tools wont boot after a fresh install of windows sammyfarr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-08-2008 09:03 PM
