Old 07-19-2021, 05:21 PM
MLaudio MLaudio is offline
Default Distortion at the end of midi clips when bussing / bouncing down???
I noticed this recently when doing sound design for a game i was working on. When bouncing a midi track to audio the tail is getting a weird kind of digital static / distortion. I tried just about everything to figure out what was causing it (removing all inserts, trying different synths, etc) but its still there. However, if i commit the midi as oppose to bus or bounce to disk, the distortion is no longer there. Check out this quick video i made of it. Curious what you guys think. This is an exaggerated example, but you get the the idea. Id suggest using headphones to hear it.
https://www.youtube.com/watch?v=_yDG9HUEc6k
Old 07-19-2021, 11:00 PM
XJENSEN XJENSEN is offline
Default Re: Distortion at the end of midi clips when bussing / bouncing down???
Do you commit at 32 bit float? How did you bounce, which settings? What is the session format?
Old 07-20-2021, 08:56 AM
Session format is 44.1 / 16. Bounce is the same. Im getting these same results whether i bounce to disk or just bus to an audio track in the session. Commit is me just right clicking the region and selecting commit.
This is on a Mac running both 2020.11 and 2021.6.
Old 07-20-2021, 09:04 AM
Well, i just discovered what appears to be the issue. I did a save copy in at 96khz and that didnt change anything. I then bumped up the session to 24-bit (44.1) and rebounced and the distortion / static is now gone.
Im a bit embarrassed for not catching this earlier!
Edit: Once this bounce is converted down to 16 bit the distortion / static is back
Consolidating clips causes distortion BLG Pro Tools 27 09-28-2023 10:12 AM
Bouncing Guitar Clips SimonBosley Pro Tools 11 2 04-29-2015 03:47 PM
Bug: X-Form replaces clips with distortion iain_m RTAS & TDM Plug-ins 2 08-16-2013 05:58 AM
Distortion/crackling clips SteveFireland Pro Tools M-Powered (Win) 1 04-13-2010 04:56 PM
Bussing/Bouncing/degradation? nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-30-2000 10:58 PM
