Old 12-09-2021, 05:19 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default This update works! 2010 12 core intel.
This update works! 2010-12 core intel 5,1
OS 10.14.6 - Pro Tools HDX 2021.12 (in Hybrid)
Edit All Night not a single hiccup.
May be my holding pattern version combo....(til Next variation CPU)
Thank you programmers!
t
Old 12-16-2021, 01:26 AM
pl007 pl007 is offline
Default Re: This update works! 2010 12 core intel.
How you installed PT 2021.12 on OS 10.14.6??? 🤨
PT Ultimate HDX system
PT Ultimate HD Native system
Old 12-16-2021, 07:55 AM
DetroitT's Avatar
Re: 2010 12-core mac pro macOS. 10.14.6
1. Update BU clone.
2. Remove all aax plugins (install out folder)
Rename current PT’s version
3. Run PT’s installer
Clear AAE prefs.
Launch PT’s, observe plugin folder repopulate.
Add back my plugin set skipping PT’s core install plugins.
ie all my plugins with new core plugins.
4. HD Driver install
Uninstall. - power off all hardware
Install driver from the PT install folder.
Restart. - launch PT’s. - turn on hardware interface when prompted.
Continue (ok). When hardware fans stabilize.
Launch - check settings - test a session
Pro Tools Ultimate (Hybrid Enabled) - HDX 1 - macOS 10.14.6
Old 12-16-2021, 09:22 PM
off the wall's Avatar
Run the installer.
offthewallproductions
Macbook Air 2014 (1.4ghz Dual-core Intel core i5 Vs. Mid 2010 MBP i7 Quad-Core and PT TheGoodhusbands Virtual Instruments 2 09-11-2015 10:49 AM
PT9 works with 15" 2.0 Ghz Intel Core Duo Macbook Pro? Max H. macOS 8 02-17-2013 09:14 AM
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? okodub Pro Tools 9 3 09-23-2011 07:33 AM
Thank You For the new update-Core Audio Works!! djmendoja 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-05-2010 10:29 PM
pro tools LE 7.XX works with intel core 2 duo? catfishblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-11-2006 12:11 PM
