Re: Click Track/Metronome Question
Go to tracks, at the bottom of the pull down there is create click track.. create click track.. make sure the output of the track is 1-2, make sure metronome button on transport is enabled. Bingo.. you should be good. So create a new session and try that. ff Oh yes, you are going to get a lot more help around here if you DONT post multiple times in multiple forums on the same issue!1 |
I will see to it that I dont post in multiple threads. And as you suggested I created a completely new session and it did work. Some settings might have changed. Thank you so much. Well I would appreciate if you can help me out in one of my other thread i have on PT LE update 8.04 and is all the issue fixed with that.
Thank you once again. |
Read the above posts about using the PT click track from the menu.
Make sure you have the metronome highlighted on the transport, and that you selected some kind of sound. When you make the click track from PT, there is a menu of sounds to choose from. Just pick one, and make sure that track's output is going to your main outs. It's that easy.
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
It finally worked but the built sounds of the click is really not at all good can we add our own click sound is that possible?
Metronome/click track volume control? | GrievousAngel | Pro Tools 9 | 2 | 12-30-2011 02:30 PM |
metronome (click track) volume controls | frcjt | Pro Tools SE and Essential (Mac) | 0 | 12-18-2011 07:47 AM |
Click track Metronome Sporadic beats 7.3 | REH | Pro Tools M-Powered (Win) | 1 | 10-17-2009 01:07 AM |
Metronome Click Track Customizing | Blissfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-26-2007 08:21 PM |
Click Track (Metronome) | jamestherouxband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-05-2002 05:45 PM |
