Tempo settings
For whatever reason it won't let me set my tempo higher than 125... Was it always like this? Am I forgetting something? Is that normal? Help thanks.
Sent from my SGH-T769 using Tapatalk 2 |
Re: Tempo settings
Whenever I try to tap tempo etc... It tells me that the tempo can only be set from 1 to 125... I don't remember it being that way I'm wondering if I inadvertently hit someting or changed some setting to make it like this. Thanks.
Try this method http://www.youtube.com/watch?v=y3HHa...e_gdata_player
Re: Tempo settings
That is not right....
Pressing T while clicked in the tempo on your transport (with conductor turned off ) only lets you go up to 120bpm? I can go up to 500 if I can press it that fast.... |
I agree. I'm doing a song right now and have been using this to go between 134 and 155 just yesterday. Check the setting in the time signature for whole note, half, quarter etc. I believe having this set to whole(big maybe) restricts the tempo. Try different settings. Totally going off a distant memory while I was setting up session time signature/ grid resolution. I remember an anomaly like this.
Re: Tempo settings
Anyone ever figure this out? Getting this today in a huge session with a ton of mapping - won't let me go over 125 when doing a gradual speed up of tempo. My resolution is set to 1/4 note…this makes no sense? In PT11HD as well as PT10HD…
Help! |
Re: Tempo settings
Double check the resolution (to the right of "Tempo") in the MIDI Controls in the Transport or Edit Window. I'll email you to get a copy of the session (if you can't solve it).
• linkedin •
Re: Tempo settings
The resolution of the first tempo marker was indeed 1/4 note, but there's an advanced box in the tempo change window I've never seen before. For some reason, it's being defaulted to whole note? This has never happened before. I opened it up in PT12 before realizing it, but I was able to make it work by adjusting that.
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
Pro tools tempo wont match keyboard tempo via midi | Killah Kane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-18-2010 01:55 PM |
Ramping a Tempo Change (interpolation or discrete tempo points) | edgarbc1 | Tips & Tricks | 3 | 02-18-2009 12:55 PM |
Preserving Markers/Tempo/Meter Settings | ratava | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-31-2007 01:53 PM |
Delay Settings w/ Tempo | git1song | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-30-2002 08:39 PM |
