Core Audio and iTunes
Hey all
I am very well versed in the ways of Panther. Perhaps someone could help... Can I play the sound that would be traveling from iTunes to the built in headphone jack on a G4 through PTLE (001)? Or do I need to get a soundcard and connect its output to an input on the 001? Thanks Chris
Digi 001 G4 w/ Giga 1.3 900 mb RAM LE 6.4 Virus C, Akai S6000 Mackie analog 8 bus a boatload of cables and mad patience... |
Re: Core Audio and iTunes
From your System Preferences pane, under 'Sound', if you select the Mac's output, you'll get iTunes through the headphone jack. Select 'Digi001' and, well, you know....
www.myspace.com/krou |
Thanks pk! Which out put will it come through? The 1-2 monitor mix?
oh, and by the way, I meant to say that I was NOT well versed in Panther...oooops. Thanks again for you help Chris
So I just went to system pref/sound and set the output to digi 001. It is still coming out of the G4's built in speaker. Any idea why? Did I miss a step with CoreAudio or something?
Thanks Chris
Go through your Core Audio setup in the Mac, make sure the Digi001 is selected.
Core Audio: PT + iTunes + whatever | Sounds Expensive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-17-2008 08:13 AM |
Core Audio-Itunes | Greene | Pro Tools TDM Systems (Mac) | 2 | 03-12-2006 04:04 PM |
002 Core Audio w/ Itunes | Rustyd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-03-2003 04:43 AM |
Core audio and itunes | Atrophied | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-09-2003 04:24 PM |
iTunes 4 and 001 core audio | gonzolagonda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-31-2003 06:23 AM |
