Old 03-08-2024, 10:18 PM
stevedresser83 stevedresser83 is offline
Default Dropping the ball with Melodyne window
They say that you can even move the window to a different screen. It seems you cannot, at least on a PC. Plugins drag fine to my secondary screen, but not the melodyne window. Anyone else have any luck, maybe on a mac?
Old 03-08-2024, 10:47 PM
Default Re: Dropping the ball with Melodyne window
figured out the workaround. Would be nice if the melodyne window could move like plugins however.
Old 03-08-2024, 11:02 PM
noiseboyuk noiseboyuk is offline
Interesting - it (and clip FX) moves fine between windows here on Windows (funnily enough), but only within the PT space. But unlike normal effects windows, it cannot be moved OUTSIDE the PT space.
I have 4 monitors and PT is expanded across two (central and right). I usually have all my FX widnows on the right, so Melodyne and ClipFX sit perfectly there. However I have meters on the top window and LH windows, outsdie the PT space - I couldn't put Melodyne or ClipFX on those screens.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 03-09-2024, 09:19 AM
yea ive been running 2 monitors with some plugins like meter stuff in the non-protools space. When I read the update I imagined that melodyne could move out of protools space like plugins.
Old 03-11-2024, 08:49 AM
Prabha Prabha is offline
And the workaround you found is?
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Melodyne Ara floating window Arionas Pro Tools 11 06-20-2023 11:17 AM
Melodyne stand alone window stevedresser83 Windows 4 04-17-2023 06:01 PM
Problem Dropping Wavform from transfuser into Pro Tools edit window SSB Windows 0 02-22-2013 05:21 AM
Problem Dropping wavform from transfuser into pro tools edit window SSB Windows 0 02-22-2013 04:48 AM
Diagonal scrolling with mouse ball not working in the edit window. AndrewG Pro Tools M-Powered (Win) 0 05-05-2010 05:34 AM
