using YOU SEND IT- sending audio files
Do you reccommend sending audio files through you send it. com? I am still trying to send session file through internet. I am having trouble sending all audio files, with you send it, it will only let me send one at a time. I tried to shift click all audio files, but only one at a time will highlight. How do you send all audio files? I believe I sent the sessio file folder correct.
Re: using YOU SEND IT- sending audio files
Compress the session into a single file using winrar, winzip, or stuffit prior to uploading.
Cavell Studios |
I think one file at a time is the rule, but as importantly, I've used it once or twice when the transfer never completed. I send a tiny file to make sure it's in a good mood before I upload megabytes.
002R Win7, no PT GigaByte 970A-UD3/AMD FX(tm)-8120 8GB DIMM DDR3 AMD Radeon HD 6570 2 WDC WD10EURX-63FH1Y0 www.soundchasm.com |
I've completed several long distance projects since I found yousendit in January. Typically sending large wav files, but I have sent zipped folders as well.
hitwriter,
Yousendit can be slow/busy at times..understandably so. And uploading is always slow. Put the entire Session folder in a zipped archive and send it at late night. Eat dinner, have a couple of pints and take your dog for a walk.. good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Huge delay when sending from a channel which is record enabled to an external send | Thirtythr33 | macOS | 2 | 07-28-2013 01:03 PM |
sending just aaf file w/o audio files | paulmmoran | Post - Surround - Video | 6 | 02-24-2012 12:45 PM |
Pro Tools Le 8 ( Midi Controller-Audio files/ Send Channels) | sweetambition4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-10-2011 08:59 AM |
Sending audio/video files by email. | nate9 | Post - Surround - Video | 9 | 04-23-2008 12:11 PM |
copy a send (w/send level intact) from 1 to 30 audio tracks? | MixerGuy | Pro Tools TDM Systems (Mac) | 3 | 12-30-2007 03:20 PM |
