Old 02-16-2005, 05:31 PM
pitman pitman is offline
Default Most up to date PT version running G4 w/10.2.8??
One of my setups:
Mac 867mhz G4
10.2.8
HD3
PT 6.1
What is the most up to date version of Pro Tools that will run in a G4 with Jaguar 10.2.8?
Unlike my G5 w/HD3 accel the G4 hasn't had this rash of kernel panics going around.
However, I am missing the new PT features. Can I install 6.7cs8 in this machine?
Old 02-16-2005, 05:38 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Most up to date PT version running G4 w/10.2.8??
Pro Tools 6.2 is the last version that will run on a G4 under OS 10.2:
http://www.digidesign.com/compato/
Previous TDM Software Releases
Pro Tools|HD 1, HD 2 , HD 3 & all HD Accel
Pro Tools 6.2 for Mac OS X 10.2
http://www.digidesign.com/compato/osx/jag/hd62/
Pro Tools 6.2r2 is the only version that will run on Jaguar on a G5:
http://www.digidesign.com/download/62r2/
Administrator
Old 02-16-2005, 05:59 PM
Tweakhead Tweakhead is offline
You should upgrade to Panther. It is far more stable and has many superior features to Jaguar.
Then buy PT6.4 or PT6.7 (if you don't need to record a lot of tracks simultaneously)
Thanks Digi.
Will the same G4 run 10.3.8 and 6.7?
Old 02-16-2005, 06:20 PM
Nexxt Nexxt is offline
Depends on whether it's a QS Quicksilver or MDD 867mhz G4.
The MDD will, the QS is not recommended or tested.
Hint: try the compatibility docs.
Not Tested or Recommended with Pro Tools 6.7:
350 MHz Power Mac G4
Dual 450 MHz Power Mac G4
400 MHz Power Mac G4
466 MHz Power Mac G4
533 MHz Power Mac G4
500 MHz Power Mac G4
667 MHz Power Mac G4
733 MHz Power Mac G4 *
733 MHz Power Mac G4 QS
800 MHz Power Mac G4 QS
867 MHz Power Mac G4 QS
Dual 800 MHz Power Mac G4 QS
*Early "Digital Audio" 733 with level 3 cache
When it's perfect, there'll always be another change!
Old 02-17-2005, 04:51 AM
Jsalam112 Jsalam112 is offline
I have an 867 QS and realize it hasn't been tested etc.
Does that mean 6.7 will not work period or install at your on own risk?
Is anyone running Panther and 6.7 on this model?
Old 02-17-2005, 05:36 AM
The only reason I'm thinking about updating this system would be to access the newer MIDI functions in Pro Tools for the occassional MIDI that is done i.e. drawing tempo changes. This is an HD3 system. I don't recall getting kernel panics. On the other hand the G5 HD3 accel combo appears to get them quite often.
Old 02-17-2005, 05:47 AM
ChaplainPC ChaplainPC is offline
My guess is that your G4 should work fine assuming you are not needing a fully maxed out set up with lots of soft synths and the like. I use the 933 w/o problems.
Pete Studio
Waves - Does WUP count from the date of purchase or the date of install/registration? abzic AAX Plug-ins 3 07-07-2013 12:02 PM
Recent Purchases - what counts? registration date OR actuall date on the bill? danijel General Discussion 4 05-25-2013 07:56 AM
Protools 10 Trial Version Release Date ? airon Pro Tools 10 1 11-08-2011 01:32 AM
Date for version 8? Dopamine Pro Tools TDM Systems (Mac) 6 10-13-2008 01:10 PM
digi001 PC VERSION RELEASE DATE musicfest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 04-29-2000 03:01 AM
