Old 02-07-2018, 12:01 PM
Fezzler Fezzler is offline
Default Looking for Tempo Map Tip
New to Pro Tools 2018.1.
I do covers of '50s, '60s and '70s songs. I like to drag a copy of the original song to the top track in a project to use as a reference track and template.
I also like to do my covers with a consistent tempo.
As you know, the tempo drifts on many of the older songs. I know how to analyze a few measures, set transient markers and create a tempo map in other DAWS. Then I quantize the tempo map to my grid or a consistent tempo.
I'm not asking for a step-by-step tutorial here, just some direction.
In Pro Tools, would I be using Beat Detective to do this? Does Beat Detective create a tempo map? I see many YouTube videos using Beat Detective for drums but I typically have to do a lot by hand.
Thanks.
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3
Old 02-07-2018, 12:22 PM
mandal mandal is offline
Default Re: Looking for Tempo Map Tip
Set cursor (slip mode) on every beat and press:
Ctrl + I
...and adjust the value in the popup.
Now, the grid will adjust to your tempo!!
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Old 02-07-2018, 01:13 PM
Ctrl + I
Ah, thanks! But after I map the drifting tempo of the imported song, I want to map its varying tempo to my grid set tempo and stretch (elastic?) the audio.
Old 02-07-2018, 04:03 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I think maybe you could use digigroove templates for this. I haven't actually done it just read about it. You turn your map into a digigroove template that can be saved and applied to another track. Hopefully someone who uses this can chime in
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 02-08-2018, 12:08 AM
https://www.youtube.com/watch?v=Z0xl...MUmzw&index=68
Avid OMNI PCIe
Old 02-08-2018, 07:31 AM
Ben Jenssen's Avatar
Tempo mapping equals having the grid line up to the varying tempo of a recorded piece, by inserting tempo changes in the tempo ruler in PT.
You want to adjust the recording to fit a fixed tempo, and that means using elastic audio and manual work.
The basic procedure that I use at least goes like this:
- Find the appx. tempo of the track by playing it, click on the tempo field in transport window, and tapping 'T' key. You'll see the tempo value will change to match your tapping.
- Find a good bar one in the track and place it on the grid on, say bar five. turn on the metronome and the tempo should match for a few beats until the recording starts to drift.
- Turn on elastic audio polyphonic and set the track to ticks instead of samples.
- Set the track to warp view.
- Place a warp marker on your bar one.
- Find, say bar one of verse two, and place a warp marker there too. If it's not on the grid line, drag it there.
- Find bar one of verse three, place warp marker and line it up to the grid.
Repeat until the end of the song, and you will have the audio roughly adjusted to match the grid and the tempo you chose in step one.
Play the track and the click, and insert more markers and fine tune it until you're happy with the song matching the click.
At least this is how I do it.
Oh, and here's a lot of tutorials on this on youtube.
Old 02-08-2018, 08:26 AM
wwittman wwittman is offline
this is, of course, the secret to making " covers of '50s, '60s and '70s songs" sound and feel nothing like " '50s, '60s and '70s songs"
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 02-08-2018, 01:23 PM
64GTOBOY's Avatar
^^+1
I misunderstood- I thought OP was trying to copy original groove to new production, which I think is a pretty cool idea actually. I completely missed this "I also like to do my covers with a consistent tempo."
Old 02-08-2018, 01:45 PM
One option; run the originals thru Melodyne(stand alone version) and flat-line the tempos.
Old 02-08-2018, 02:24 PM
OP might just want to do cover versions with a modern feel and I for one don’t really see what’s wrong with that. It certainly doesn’t deserve a catty pointless response like this.
How do I match tempo of rex2 loop to master tempo siuberto Socarras 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-27-2010 11:23 AM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Tap tempo and involuntary time shifting with tempo changing Skiroy Pro Tools M-Powered (Win) 3 08-26-2010 10:00 AM
Pro tools tempo wont match keyboard tempo via midi Killah Kane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2010 01:55 PM
Ramping a Tempo Change (interpolation or discrete tempo points) edgarbc1 Tips & Tricks 3 02-18-2009 12:55 PM
