Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-18-2020, 12:36 AM
Noteon Noteon is offline
Default Melodyne issue
I uninstalled Melodyne 4 with cleanmymac x. Also checked library (both) contents, nothing, every place seems to be empty, also spotlight didn’t find any Melodyne files. Also I reinstalled PT. Melodyne 4 is still in pro tools and no melodyne 5 essential. I didn’t find melodyne´s own uninstaller. Using PT 2020.11 and latest Mojave. Any advice?
-janne
Old 11-18-2020, 04:11 AM
apbaudio01 apbaudio01 is offline
Default Re: Melodyne issue
Had similar problem, solved with free upgrade from Melodyne 4 to 5 which then appeared in PT 2020.11 Prefs straight away
Old 11-18-2020, 07:59 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Audio AAX Plugin folder, remove melodyne, reinstall PT’s
Go to Celemony and register Melodyne v 5.1
(Found in your Avid account)
Launch Pro Tools.
Old 11-18-2020, 08:20 AM
Done that all twice. AAX folder doesn´t have it, Melodyne 4 is still in the Instruments category when I open pro tools.
-janne
Old 11-18-2020, 08:42 AM
Had similar problem.
Free upgrade from Melodyne 4 to 5
Pro Tools Prefs saw it straight away.
Old 11-18-2020, 08:56 AM
ChuckS ChuckS is offline
Check for the Rewire component in Library/Application Support/Propellerhead/Rewire. Not at the Mac so that folder path may be slightly off, but will get you close. If on a PC look here: C:\Program Files\Common Files\Propellerhead Software\ReWire
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 11-18-2020, 10:20 AM
Southsidemusic's Avatar
We had to reinstall Melodyne Studio 4 3 times before we installed our update Melodyne Studio 5.1 so make sure you deleted preferences aswell.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-19-2020, 03:11 AM
Thanks Guys, now it works! Melodyne 5 running beautifully. I removed rewire folder, all pt prefs, and reinstalled PT.
-janne
Melodyne 4 Transfer issue with ProTools 12.5.1 kehlers Pro Tools 12 4 12-23-2016 02:39 PM
Melodyne Window Refresh / Scrolling Issue in Pro Tools 10 Harliraha Pro Tools 10 3 05-15-2013 09:21 AM
ProTools with conductor (variable tempo) and Melodyne issue. Please help! Zarabozo Windows 7 04-21-2011 01:07 PM
Melodyne Editor/ PT8 issue summit01 Pro Tools TDM Systems (Mac) 7 02-02-2010 03:43 PM
Melodyne Audio Capture Issue JasonMartinez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-21-2008 12:50 PM
