Old 01-14-2014, 12:22 PM
syndicat syndicat is offline
Default AIR Collection plugins not loaded after Upgrade to PT 11.1.1 [solved]
after upgrading from PT 11.1 to 11.1.1 i did not get the AIR Collection AAX plugins loaded any longer (i.e. Xpand2, Boom, MiniGrand).
Pro Tools shout out an error that it can not load these plugins because they are not 64bit aax compatible (hmm, but still used it in PT 11.1).
I did reinstall the AIR 11.1 (which seems to be the newest in my account beside PT 11.1.1) to the default location with no luck. Other plugin are not affected.
Any ideas or solutions around or anyone with the same problem?
Many thanks for any hint!
cheerioh,
Niels.
Old 01-14-2014, 06:11 PM
Southsidemusic's Avatar
Default Re: AIR Collection plugins not loaded after Upgrade to PT 11.1.1
Hi
Have you deleted preferences and databases and especially the plist files and the air plist files. This way PT cleans out all the plugins and rescan them from start. Takes a few minutes but it is a one off so next time PT will start up normal.
Best
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-16-2014, 12:19 PM
Default [SOLVED] AIR Collection plugins not loaded after Upgrade to PT 11.1.1
Hi Southsidemusic,
thanks for your reply.
I've found the solution: After deleting all of the regarding AAX plugin files by hand from the AAX plugin directory (with timestamps from june 2013 where i installed PT 11 and Air Collection 11.0) and reinstalling the AIR Collection 11.0 i can load / access them again. Not shure why it had worked in PT 11 but this was a solution for me...
many thanks for your time.
cheerioh,
Niels.
How do I install Air Creative Collection 11.1.0? [solved] JGlen Windows 4 12-26-2013 04:45 PM
CPU usage holding off when samples plugins loaded alfredogzz RTAS & TDM Plug-ins 6 04-03-2013 09:10 PM
Help! PT8 loaded ... authorizing plugins and weird error!? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-08-2010 09:18 AM
Loaded Plugins? saroehr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-10-2010 07:05 AM
Need Help - Creative Collection´s Virtual Instruments wont load! SOLVED hernan1987 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-11-2009 08:14 AM
