Old 05-18-2020, 07:04 AM
old betsey satan old betsey satan is offline
Default Playlist Editing: is there a Key Command/Preference for "Solo Follows Selection"?
Hi guys,
So I'm getting (or at least trying to) more acquainted with the latest playlist comping features (I think I stopped any new discovery back in PT9!) and was wondering if there's a key command or preference (or combination of both) that allows a channels solo state (within the playlist) to follow the selection?
As it stands now I can tab (P / semicolon) my selection up and down between takes but in order to solo the new selection I need to SHIFT+S on each channel to engage solo.
So, yea, just wondering if there's a command/preference that allows the solo to follow the selected channel when tabbing through the takes?
Cheers!
R.
Old 05-19-2020, 11:56 AM
Default Re: Playlist Editing: is there a Key Command/Preference for "Solo Follows Selection"?
I'd take a look thru the manual. While I don't think there's an option for what you want, there are some key commands for moving from PL to PL, so maybe that could work with a little modification to your current method
Old 05-19-2020, 04:36 PM
Cheers Dave!
Yea I looked and looked but definitely couldn't find anything like that.
There must be some reason in the post-pro world that they wouldn't want that behaviour as it seems that 'solo follows selection' (or some such) would be a no-brainer especially when shuffling through playlists.
Knowing my luck it's there in plain sight but called something else and I'm just too blind to see it!
R.
What is the key command for "link track and edit selection"? jkuehlin Pro Tools 10 5 10-21-2023 05:07 AM
Create New Playlist "Command+\" on Foreigner Keyboard? Spidouz Pro Tools 9 23 09-02-2020 01:30 PM
preference to DISABLE edit mode command "clutch"/toggle from 12.6 bolooki Pro Tools 12 7 05-25-2017 12:13 AM
PT 12.6 "Repeat to fill Selection" editing BUG (repeatable) reichman Post - Surround - Video 22 12-22-2016 08:33 AM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 03:46 PM
