Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-19-2012, 02:46 AM
Hamdi Hamdi is offline
Default Calibrating old 192 which reference level?
Hi DUC,
Which calibrating reference level should I use for audio, -20dB 0r -14dB
or what is the best reference level for audio?
Thank you.
PTHD9.0.3
192
Old 07-19-2012, 08:56 AM
Drew Mazurek's Avatar
Default Re: Calibrating old 192 which reference level?
I believe they come from the factory at -18. Just leave it IMO.
www.drewmazurek.com
Old 07-19-2012, 07:14 PM
janmuths janmuths is offline
That really depends on what you're going to do. For many post applications -20 is the way to go. Are you running the interface with others such as 96io lynx apogee? Then match the level.
I run my 192s at -24db for max headroom.
Hope that helps.
J.
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
Old 07-19-2012, 11:03 PM
Janmuths,
I'm only using 192 with Presonus Digimax LT.
Thanks you.
Specs for Broadcast, Leq(a), Peak audio and reference level yazoo Post - Surround - Video 7 04-04-2011 08:26 AM
What is the mixing reference level for TV and DVD critictalk Post - Surround - Video 27 01-15-2011 03:17 AM
Need help calibrating room and setting up reference monitors Premo Pro Tools TDM Systems (Mac) 5 01-30-2009 12:48 PM
reference level discussion, please! AdamFrick Pro Tools TDM Systems (Mac) 9 04-09-2002 02:32 PM
Calibrating Dirt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-11-2000 06:48 PM
