Old 01-27-2011, 10:03 AM
henryrobinett henryrobinett is offline
Default New here! A few Newbie PT 9 Questions
Hello folks! This is my first post here. I'm a newbie PT user. So please forgive my silly questions. I have looked through the manual and looked at some videos and have been mixing a CD on PT9. I'm loving it. I come from the DP world.
I don't know whether I should separate these questions into different threads, but -- I don't know. That seems like a waste of space. We'll see.
First -- When setting up tracks, can I select a group and set up inputs, busses all at once, rather than individually? In DP I can highlight a group and set inputs outputs to go consecutively or all the same. This would be a time saver. I'm sure it does this. I just don't know how!
Second - Can I set loop points and work with automation in a looping cycle? Right now when I loop and start automation moves the automation stops when it comes back to the top. In DP I could mix sections by loops point cycles.
Also, is there a way to import mixing board from another file or template to a file already opened and working? As in I have a project that shares the same tracks and I/O set ups. I've got the mix perfect on another file, but want to use that as a template to another file I'd already worked on.
Thanks for your help? I hope those questions make sense!
All The Best,
Henry Robinett
System 1 - Mac Pro Quad 2.8, 10.7.4 ULN-8 (x2), ULN-2, PT9, UAD2-Solo, DP 7.24
System 2 - Mac Pro Quad 2.66, 10.7.4 ULN-8 (x2), PT 9, DP 7.24
Old 01-27-2011, 10:08 AM
Meads Meads is offline
Default Re: New here! A few Newbie PT 9 Questions
First -- Select the desired tracks, then hold shift+cmd and select your input/output. This will apply to all selected tracks. If you want to apply it to all tracks, press alt.
If you press shift+alt+i you can select the session file you want to import the tracks from, and in the upcoming dialog you can select the tracks, and what parameters should be imported with them (i.e. inserts, automation, regions, etc).
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 01-27-2011, 10:16 AM
I'll have to try and apply these ideas later. Thanks Meads! But I'm not sure what bleep, bleep,bleep means. Hm. [edit] Must've been edited out. I thought I tried this but I'll try again!
All The Best,
Henry Robinett
Old 01-27-2011, 10:17 AM
Sorry, I spelled s*h*i*t instead of "shift". That gets bleeped out by the forum software. I corrected it.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 01-27-2011, 10:20 AM
Does this apply to inserts/sends or just I/O?
All The Best,
Henry Robinett
Old 01-27-2011, 10:21 AM
This also applies to inserts and sends.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
[IMG] code is Off
Newbie questions on laptop PC selection - basic questions - thanks... half drag Windows 0 01-04-2011 01:12 PM
newbie to PT8 LE with some questions nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-26-2009 09:36 PM
newbie questions please help chunkymutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-30-2004 05:44 AM
Newbie with a few questions. The_Communist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-04-2003 01:16 PM
Midie Newbie with newbie questions. cydonia MIDI 5 08-11-2002 02:24 AM
