Old 04-20-2005, 07:57 AM
knewbee knewbee is offline
Default Griffin G4Port serial MIDI interface on OSX PT?
Greetings,
I have recently installed PT 6.4.1 on my dual-boot G4, just now getting my feet wet with OSX.3. Yesterday for the first time I tried to do some MIDI work in PT 6.4.1, having not previously run the MIDI studio setup. I am running a Motu MTP AV. It is running off a Griffin G4Port serial adapter card. (It works like a charm under OS9). I downloaded and installed all the appropriate OSX drivers from the Griffin website, but I cannot get the PT Midi setup process to see my interface. Is there a step that I am missing? If I install the correct drivers for the G4Port, then PT should be able to see the serial port, correct?
Is there anything I can do to get this interface running under OSX and PT 6.4.1. I do not want to buy a new MIDI interface. Thanks - Steve
(p.s. I'm stuck with this version of PT, since I'm running Mix cards...)
Old 04-20-2005, 08:10 AM
Seeee Seeee is offline
Default Re: Griffin G4Port serial MIDI interface on OSX PT
create a multi poirt device in the griffin utility then that will show up in AMS
Old 04-22-2005, 06:47 AM
Cool. Thanks for this. But where is this Griffin utility thing? What's it called? I didn't see that it installed anything except the driver, and I didn't see any kind of utility download on the Griffin site...?
Thanks!
Old 04-22-2005, 12:31 PM
it might be an application but it's there if not then I would check your install disk if you have it. I'll have to check when i get home but it is required in order to be able to define a multi port device in AMS.
Old 04-22-2005, 07:38 PM
drumbar drumbar is offline
Default Re: Griffin G4Port serial MIDI interface on OSX PT?
I think s its on the Griffin website. It is a separate application that will allow you to create an interface which AMS will see.
Will 002 work with g4Port serial adapter in OS9? JoeM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-08-2010 12:50 AM
Griffin g4Port stable in 001 & PTLE 6.4-OSX 10.3? JoeM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2005 09:00 AM
Griffin G4Port supported in OS X? 1150Post Post - Surround - Video 4 11-11-2003 04:58 PM
What's prefered for G4 serial MIDI:GeeThree Stealth Port or Griffin g4Port ? JoeM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-22-2002 08:31 AM
Griffin g4Port or GeeThree StealthPort? iris-audio Pro Tools TDM Systems (Mac) 3 11-05-2002 09:58 AM
