Old 03-17-2010, 07:37 AM
SNAPPER SNAPPER is offline
Default td-9 with ezdrummer-hihat issue
So I got my td-9sx kit to trigger drums correctly in pro tools using the ezdrummer plug. the only issue is that the hi-hat does not trigger correctly. It seems to use the open-hat sound even when the pedal is depressed. I know there are issues with hi-hat triggering but i have not found any detailed instructions. is it just a matter of midi map tweaking? all other sounds work great, toms, kick, snare,cymbals,etc.....
Thanks
Help needed with EZDrummer issue boycie Virtual Instruments 4 04-11-2012 04:37 PM
Need Ride or HiHat Mic, which one? Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-22-2009 10:09 PM
POD Farm Plug-In same issue as EZdrummer in PT 8 LE shredhed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-19-2009 05:03 PM
M-Powered and EZdrummer issue Mad Genius Audio Pro Tools M-Powered (Win) 1 10-24-2008 06:20 AM
fav. hihat mic ? tantejo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2004 09:00 PM
