Plugin's will not go away . . .
All,
I have ProTools 10.3 on a MacBook Pro, running OSX 10.8.3. I recently removed a trial version of the WAVES Plugin Tools. Everytime I start PT up, it scans and ask me where the plugin's are. I am obviouly new at PT's - can someone please point me to how I can correct this issue. Thanks ! |
Re: Plugin's will not go away . . .
You should have the following file already on your computer:
/Applications/Waves/Utilities/Waves Uninstaller.app That should get rid of everything that waves installed. Or you can at the least do the following manually... Check to see if you have something with the name "WaveShell" in the following location: Macintosh HD/Library/Application Support/Digidesign/Plug-Ins If you do not have or plan on using any Waves plug-ins, delete that WaveShell file. |
Thanks Bruce !
_______________________________ Mac Mini OSX 10.9.2 ProTools 10.3 Eleven Rack + EXRP http://www.phatguitars.com |
Pro Tools Le - Plugin's. | Maaybach | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-08-2010 01:18 PM |
plugin's and recording | david foreman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-24-2009 08:11 PM |
Compressor plugin's? | Edson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 03-21-2007 09:40 AM |
How to set up plugin's in reason | geemcc | Tips & Tricks | 12 | 01-24-2006 08:26 PM |
Can Mac 001 plugin's be used with Windows? | piccolo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-10-2002 03:38 PM |
