Old 08-29-2014, 11:13 PM
Kinh Kinh is offline
Default How to bypass global volume expression pedal?
Hi, I cant route expression pedal properly cause its stuck in global for most synths...Omnisphere, nexus, hybrd to name a few. Massive is the only one that doesn't have a global setting locked in so I can modulated anything to it.
However the others have volume triggered every time I use the pedal, so if I want fx mix or filter cut off etc I have to also have include volume too. Is this a protools issue or midi controller or plugin issue? I just cant seem to find a way around it. There has to be a fix otherwise why bother even having an Omnisphere matrix with expression as a source?? It defies logic if it's gonna trigger volume too.
Intel 6 Core i7-4930K CPU @ 3.40GHz
32GB DIMM DDR3 G.Skill
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
Windows 7 Ultimate 64
Mbox3 Pro Firewire 400
ProTools 10.3.8
ProTools 11.3.1
https://soundcloud.com/matthewcrowe
Old 08-30-2014, 02:53 AM
Default Re: How to bypass global volume expression pedal?
Have you tried using the midi-learn function?
Old 08-30-2014, 03:02 AM
Yes but the expression -> volume default overrides any routing of midi learn or otherwise.
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
ProTools 10.3.8
ProTools 11.3.1
Old 08-30-2014, 02:22 PM
What keyboard controller are you using? Does it have a second expression pedal input?
ErnieBall VP Jr Volume Pedal as expression pedal. cohensm Getting Started 7 07-06-2014 07:48 PM
Xpand2, want the volume/expression pedal to be something else! fredmant Virtual Instruments 2 01-13-2014 02:18 PM
New User:help with expression pedal volume gp81 Eleven Rack 7 09-23-2013 09:00 PM
Expression pedal > Rig Volume > on To Amp out as well? therealmf Eleven Rack 5 10-17-2010 11:55 AM
expression pedal for track volume: live acroamatom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-06-2008 09:12 PM
