Digi 003 with external preamp. How can I check signal in protools instead of recordin
Hi everyone,
I just got a new preamp that I connected to inputs 5 and 6. When I want to record through the preamp, I can't check the signal inside Pro-Tools, I have to actually record then the signal appears on the track. Is there a way I can fix this so the signal can be read easily like the mic pres from 1-4?? |
Re: Digi 003 with external preamp. How can I check signal in protools instead of reco
Huh? As soon as you put an audio track in record-ready, the meter should be showing the signal level(always has for me). Have your meters in PRE-fade mode. Assuming your new preamp outputs a +4 signal, use that switch selection on the back of the 003 for inputs 5&6
Problem was solved. It already was at +4, so I must've done something without realizing it, or maybe it was just a bug inside Pro-Tools.
Thanks |
Don't forget, trashing prefs and database files is a good idea for any "odd" behavior of Pro Tools
Yes, I'll keep that in mind
Alt/opt K will give u the auto input monitoring
Digi 002 preamps with external preamp | elandrue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-22-2008 09:06 PM |
Low signal from non-preamp channels | artbrut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-09-2008 11:39 PM |
PLEASE HELP! Recordin with Triton on MBox and ProTools LE | soitis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-18-2007 02:55 AM |
Protools not reading signal through preamp | unseen33 | Pro Tools TDM Systems (Mac) | 5 | 02-16-2007 09:20 AM |
Recordin Guitar Rig 2 using Protools HD real time | HYR | Pro Tools TDM Systems (Mac) | 7 | 02-05-2006 11:43 AM |
