PT System Freezing every 20 minutes
We are having a problem on a newly built system on older hardware that we could use some help with:
After about 20 to 30 min of use, the computer freezes (total lock up - no error message) when trying to import audio either from FILE or AUDIO or when trying any other random comands in edit window. Our Configuration: Mac 9600/350 4Gig w/ Power PC Enabler9.0.4 - G3 Card - SCSI card is Adaptec 3940OUW, model:942106-00 - Miro Motion DC30+ v 2.0 - Digi 001 System 9.0.4 Finder 9.0 Disk cache 512k, built in memory 320 quiktime 4.1 Protools LE 5.1 Any tips/thoughts would be appreciated. Thanks Mark manexmachina AT yahoo DOT com (I clarified the system details in the edit of this post) |
Re: PT System Freezing every 20 minutes
I recently had a similar problem. Try removing your Preferences folder from the System Folder to the desktop.Don't trash it yet. The OS will create a new Preferences folder with the default settings.(you may need to restart) This was the fix for me. If it works you can check the previous folder for settings you may need and either drag back or trash. Tip: It's best to just reset everthing that needs it and get rid of the old Prefs.Obviously, that way you're sure you got the bug.
Hope this helps.
Mbox /PTLE 5.2 G4 QS Dual 1Ghz OS 9.2.2 512mb RAM 80 G Seagate internal HD 60 G IBM Deskstar internal HD 40 G Buslink (Seagate)FW ext.HD |
Does it freeze only when you run Pro Tools, or will it freeze by itself or any with other application ?
Take Care, Gene
Unicycle Studios |
The only application on this computer is ProTools, so it hasn't crashed on any other program simply because there hasn't been that option. However, technically the Finder is an application and so the answer would be "no."
Keeps freezing after just minutes of being on. Have 2 force restart PC. Sandra inside | JLiRD808 | Windows | 4 | 10-03-2012 10:31 PM |
computer randomly freezing for a few seconds to several minutes | audiogeekzine | Pro Tools M-Powered (Win) | 2 | 09-30-2010 07:41 PM |
D-Command Slows System down after 10 minutes or So | laki | ICON & C|24 | 6 | 07-24-2007 08:48 PM |
System freezing - Help | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-13-2006 12:14 PM |
HELP ! System Freezing (9073) | session48 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-17-2006 02:20 PM |
