Old 09-07-2009, 05:20 PM
Chompers Chompers is offline
Default 8.01 update...?
Does this update address the selection issue where after you click and relase, sometimes pro tools will read you movemt as a selection?
Its hard to describe. Howver, it was an issue with several othr versions of Pro Tools, and it always seems to get fixed in an update. I havent heard anyone complan about. I just figured it would be fixed soon.
The issue occurs if you select a point in the timeline, un_click, and then move the cursor. Pro tools sometimes treats your cursor move as if you were still holding down a click.
The results are a PITA. Playback stops, loops or any number of un intended actions.
Dig?
Old 09-07-2009, 05:30 PM
Default Re: 8.01 update...?
I'm getting this with MIDI notes, funnily enough. Very annoying.
Old 09-08-2009, 12:54 AM
crizdee's Avatar
crizdee crizdee is offline
Dig?
Yes i've started to get this about pt8 or maybe one of the cs updates. it seems to hold on to any click-holds for longer than necessary!! and yes this became a problem about 1-2 years ago if i remember correctly.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-09-2009, 07:14 AM
Mark Dann Mark Dann is offline
Dig?
Starting with 8.0, the tendency for that to happen went from "highly unlikely" to "I can't believe this is happening several times in a row even though I am trying my hardest for it not to happen even once". I'd love to see this fixed.
Old 09-09-2009, 11:04 PM
seems to be better after the 8.01 update.
still haven't cleared it from the annoying list yet.
HD Native cant Update Firmware after installing PT9.0.5 Update Aditu Pro Tools HDX & HD Native Systems (Win) 72 11-27-2012 03:57 PM
10.3 Update - Windows shutdown issue has returned. Update at your own risk. crm0510 Windows 14 09-19-2012 01:50 PM
10.5.6 update. Is it safe to apply the system update from 10.5.5? SBCCMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-02-2009 02:27 AM
Windows Update Vs Apples Software Update sunburst79 General Discussion 2 07-14-2007 06:40 AM
What is this Apple Update? Hard Disk Update...ver 1.0 McMasters Pro Tools TDM Systems (Mac) 1 06-30-2003 05:56 PM
