gradual time stretch
I have a piano recorded with 4 mics on 4 tracks. I want to create a ritard - to gradually slow the piano down on the last couple measures.
Does anyone have a recommended technique for doing this with minimal artifacts across 4 tracks?
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory. |
Re: gradual time stretch
Aaron Mulqueen - 001 HD Native |
I should add that when you do pin down the start of the rit. EA will add a Warp Marker at the point of rit. and another one beside it to the right hand side. To remove a Warp Marker use the Grabber tool and hold Alt and click the Warp Marker.
You may want to add additional Warp Markers in front of your desired rit. (left hand side) to edit the start of the rit. without effecting the ritardando itself just in case you like the performance of the new ritardando.
Excellent instructions above. I will add a little advice. Right after you create your group, duplicate the playlist on one of the 4 tracks(the grouping will cause this to happen to all 4). That way, if you end up with some digital artifact from the EA, you will have the original audio available for more processing(you never mentioned which PT version you have and PT8 sometimes creates a gurgling effect that renders the audio is garbage unless you, either turn OFF EA and revert(and start over) or have a copy of the original audio for a second try.
Structure Real Time Time Stretch | FedericoF | Virtual Instruments | 3 | 02-18-2010 05:30 PM |
How to Double Time (or Time Stretch) Midi? | noharmlessrock | MIDI | 4 | 04-02-2008 07:32 PM |
Time stretch? | jimbojimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-21-2006 05:59 PM |
Time Slice / Time Stretch on ProTools LE? | Gilbert Espiridion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-23-2004 12:13 AM |
Anyone know how to do this....Time Stretch... | tomhartman | Pro Tools TDM Systems (Mac) | 14 | 10-06-2003 11:18 AM |
