Old 06-11-2011, 09:14 PM
abt abt is offline
Default Import sesion data - track input inactive - SD2 Multi-out
I've created a session template to use with Superior drummer. Using the mulit out mode I've got 16 stereo aux tracks with all the kit components sent to them with all my favourite plugins on them etc. The only problem is when I try to import the session data all the inputs on the aux tracks have the correct i/o assignment but they are greyed out.
If I right click on the I/O and choose "Make active" it says "The input could not be made active because the input is forced inactive".
When importing the session data the "Track data import" "input Assignments" item is checked.
If I reassign the I/O everything works fine but the defeats the propose as creating the track assignments is the majority of the work.
Old 06-11-2011, 11:04 PM
Top Jimmy's Avatar
Default Re: Import sesion data - track input inactive - SD2 Multi-out
It sounds like their is a problem reconciling the plugin outputs as track inputs at session data import. Try importing in two steps. First, import the track with SD on it only. Then, try importing the routing tracks second.
James Cadwallader
Old 06-12-2011, 12:01 AM
abt abt is offline
When I read that I thought that would work but unfortunately it didn't.
Old 08-01-2011, 10:46 PM
hutchinson9736 hutchinson9736 is offline
I also have this problem
Did you ever figure this out?
Old 08-02-2011, 12:53 AM
abt abt is offline
Sorry but no, I never solved it. I have to remap the I/O to the plugin every time I import the tracks..
Old 08-02-2011, 06:35 AM
Same here. I just re-select the inputs.
Old 03-24-2013, 10:51 PM
mrbobb mrbobb is offline
Has anyone found a solution to this issue? I've got the same problem here on a Mac as well. Big pain.
Producer/Songwriter/Mixer
www.matchstickmusic.com
Old 11-27-2013, 05:50 AM
Dave Modisette's Avatar
Dave Modisette Dave Modisette is offline
Has anyone tried to find out through support from Toontrack or Avid whether this is a plugin issue or a host issue?
I just bought PT11 this week and I ran into the issue trying to get myself properly organized for sessions after coming from four other DAW hosts.
Is this an issue with any other multi-out softsynth?
I'd like to see this sorted out. There is no excuse for a top of the line host or soft sampler not to work as advertized with basic workflow features.
Old 04-21-2014, 10:40 AM
hugocentrique hugocentrique is offline
This is definitely a Pro Tools issue, I get this with Play and Kontakt also, under PT 10.3.4 on OSX 10.8.5
Old 04-21-2014, 12:38 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Just some thoughts:
Do you have "sessions overwrite current I/O settings" ticked in the I/O bus tab?
(Turn off to keep your settings)
Have you exported your custom routings from the I/O window?
Redue older templates by importing new I/O settings.
SD2 is in my templates and constantly works well.
Multi-Out Synth tempate and Session Data import issue. Dave Modisette Pro Tools 11 3 11-27-2013 11:47 AM
Does 10 still have the bug if Input Monitor is on a multi-channel track Craig F Pro Tools 10 0 05-05-2012 06:17 PM
AI track inactive after import sess data Boe Larsen Pro Tools TDM Systems (Mac) 2 04-22-2011 03:17 AM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
Import session data MIDI track out of time propower Pro Tools TDM Systems (Mac) 1 03-01-2006 12:35 PM
