#101
Re: Re-learning to mix ITB?
You're constant argument about floating point, clearly shows your ignorance and lack of knowledge in the real world of making records!! you have one argument about native mixing And only a complete amateur, someone with no real world experience in making records (maybe someone like yourself) would make records at those levels in the box. You insist on constantly posting in just about every thread with bad and misinformed information... "If fader position matters so much, just use a trim plugin, or a level setting on one of the other plugins." "in a modern floating point engine like LE gain structure is nearly completely ignorable ITB." "With most plugins in LE, you can run everything hundreds of db up into clip, and pull it all down right in front of the converter or filesystem without any distortion or quality loss whatsoever." There's lots os people on this forum who make great records on a daily basis! i guarantee not one of those record makers will agree with your points of view See monkey, do monkey do There's nothing more dangerous than someone with a little knowledge and a big mouth. Chris
#102
[QUOTE=WernerF;1441459]I personally prefer to mix with some mastering going on on the mix buss. That is one one of the things that makes mixing on an SSL great too.
It is "always" better to be good at mixing and leave the mastering to the ME's. We MEs receive too many records with bogged attempts at mastering. Learn to mix properly and then.......... |
#103
Learn to mix properly, learn to master properly, learn to play properly...and once you've got it, you'll be pretty old...and will have watched your friends (who never learned it properly) spend most their time in the charts
www.olipoulsen.com iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7 Apollo 8 / PT Ultimate 2020.9.1 |
#104
Chris, well said.
#105
Right On!!!
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
#106
[QUOTE=lbl;1444622]
#107
yeah....screw what it sounds like just give me the money...NOW.....i need to be rich and famous so i can afford to pay for your social security.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#108
this is the insanity of it. You mention students and teaching... Ptree then slags you and in doing so demeans teaching. He then goes off on a diatribe detailing how much he knows about teaching, including percentages. This is the MO. Unless one wants a lecture on whatever they mention, they would be wise to not engage this fella. You ever see the Geraldo interview with Charles Manson? The same logic prevailed with CM as both the misunderstood victim and the arrogant sage. And there were a handful of people both lonely and dumb enough to kill for him. FF |
#109
[QUOTE=lbl;1444622]
Of course, severe limiting during the mixdown is bad in so many ways and I believe that's what you meant
#110
Yep. The earlier the talent, the greater the benefit. If you begin postponing problems to the next phase, you'll become Frank Zappa ("We'll fix it in the shrink-wrap")...
learning the 003 factory | gclef101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-07-2009 05:29 PM |
Learning BFD???? | finalcut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-20-2007 09:49 PM |
Learning how to use EQ | Meat Truck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-16-2002 03:35 AM |
HELP...I'm still learning | CodeBlue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-24-2002 04:02 AM |
Learning how to EQ | sidereal | Pro Tools TDM Systems (Mac) | 4 | 08-19-2001 07:11 AM |
