Old 05-25-2002, 01:57 AM
Vini Vini is offline
Default hardware inserts..
i've discovered when bouncing to disk with a hardware insert, that the returning audio does not record.
it's there when playing the multitrack, and the bounce is obviously drawn from the master stereo out, but play the bounced file - it's disappeared!
anyone had this experience?
Old 05-25-2002, 06:45 AM
Mystic Mystic is offline
Default Re: hardware inserts..
Try to route all audio tracks to a sub-master (aux channel) insert your hardware on that sub master, and route the submaster to your master fader.... If that doesn't work, throw away your "digisetup" from the preferences folder.....
Mystic
Old 05-25-2002, 03:16 PM
dkrausz dkrausz is offline
Also. Make sure "Low Latency Monitoring " is off.
dk
http://homepage.mac.com/dkrausz
Old 05-26-2002, 03:26 AM
marcoustic marcoustic is offline
<font size="2" face="Verdana, Arial">Yes!
That´s the problem. I´ve had that , too.
Disable "Low Latency Monitoring " and it will work.
Some question to digi:
Wouldn´t it be possible to implement this feature to do a bounce with hardware inserts in LLM mode?
Markus
www.marcousticaudio.de
Old 05-26-2002, 03:45 AM
petter petter is offline
You can read a lot about this....E.g. :
http://duc. digidesign.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic;f=24;t=006757
or
http://duc. digidesign.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic;f=24;t=003238
“what you hear is what you get” .....Really?
I don't think so!
Old 06-07-2002, 07:29 PM
thanks to all for the replies... i've learnt the lesson of checking the manual 1st - then search the duc dbase before posting a Q.
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Hardware Inserts trackone Pro Tools TDM Systems (Mac) 6 01-27-2012 06:22 AM
Hardware Inserts on PT 9 Obe1 Windows 0 06-09-2011 08:19 AM
Hardware Inserts CosmicJunkie Pro Tools TDM Systems (Mac) 1 11-20-2007 03:12 AM
002 Hardware Inserts tele_player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2003 11:02 AM
