How do I add bar/beat markers without affecting previous bar/beat grid?
I'm music editing for a television project and am working with gigantic AAF projects with tons of cues checkerboarded throughout. Obviously, every cue has a different tempo. I'm trying to go through the project and ensure the grid follows each cue so that I can more easily edit.
This means creating a bar/beat marker at the beginning of each cue and changing the project tempo for the length of the cue. Then when a new cue begins (almost never on the current grid), I'd like to use slip mode to create a fresh bar/beat marker at the transient of the cue's first "beat", and change the tempo accordingly. Again, my goal is just to align the bar/beat grid with each song, while leaving the timecode alone. However, whenever I go to create a second bar/beat marker, it alters the grid for the entire project instead of just from that marker onward. I need the grid to be ignore the previous bar/beat grid and begin anew at that marker. The only workaround I've found is to create a grid marker at the beginning and end of each cue to "lock" that cue's grid in, then create a new grid marker for the next cue. This is kind of a pain and seems like it should be unnecessary. What's the secret here? Or is my workaround the secret? |
Re: How do I add bar/beat markers without affecting previous bar/beat grid?
Check to see if the Conductor icon is on.
With the Conductor Track icon enabled you should be able to insert & maintain several tempos at any point. You can also open the Tempo Operations Window by pressing Alt + 2 on number pad (Windows) or Opt + 2 (Mac). The default is Constant. That works just fine for insertions. Place the cursor, open the Tempo Operations Window & enter the tempo. You'll also see the option to "Preserve tempo after selection" checkbox. If selected, the previous tempo setting that was in effect at the selection end point is preserved after the selection. If unselected, the last tempo event created by the tempo operation continues to the end of the session, or until the next tempo event beyond the selected range. That enables you to maintain a previous tempo after an insertion & any other set tempos that follow the insertion. Otherwise, everything changes to the newly inserted tempo down the rest of the timeline. But that only happens if you've made a selection. For example, selecting the a song section as a whole and then entering the new tempo. You can also just place the cursor (without making any selection) & create the insert leaving the following tempos intact.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 02-25-2023 at 04:48 AM. |
Your solution of 'pinning' the last bar (or second to last bar) of the previous program is the only way you can enter new bar/beat/tempo info without changing the last previous tempo. Again, if I'm misunderstanding please explain in more detail.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
In other words, when I place my cursor at a point that is off-grid (slip mode), I'd like to be able to move the grid to that cursor from that point forward - without affecting the bar/beat grid prior to that. It really has very little to do with tempo. Here is a screenshot of how I want the grid to look (I used my workaround here). The next cue's "bar 1, beat 1" is on a beat 1 of the grid. https://imgur.com/a/pHfQ4j4 Last edited by jbmoonchild; 02-25-2023 at 06:35 PM. |
It really has nothing to do with tempo. Every cue in the project could have an identical tempo and the problem would still exist. I'm trying to alter the grid throughout the project so that the downbeat of each cue lies on a grid marker. Obviously I don't want to move the cues themselves, so I need a way to move the grid lines. The only way I can see to do this is to alter the tempo in between grid lines via my "workaround". It's pretty simple and easy to do in Logic Pro, for example. You can kind of force the grid to "start from here" at any point in the timeline. Here is a screenshot of how I want the grid to look (I used my workaround here). The 2nd cue's "bar 1, beat 1" is on a beat 1 of the grid. https://imgur.com/a/pHfQ4j4 Last edited by jbmoonchild; 02-25-2023 at 06:35 PM. |
you can cut, copy, and paste tempo events.
I'm not sure that helps with bar placement though. Again, I want bar 1 of all cues to lie on an even beat 1 of the grid.
Hmmm, how to "re-draw" the grid section by section.... Beat detective can re-draw the grid according to the calculated tempo but you'd have to analyze each section one by one. That would also alter the original timeline you were sent. Unless you made a duplicate and tried it on that. An easier idea would make a copy of the original track(s) to be edited, then copy each section to it's own playlist (making note of the tempo in the clip or playlist name). Now you can edit each section one at a time in accord with the main timeline at the specified tempo. After choosing the next playlist, simply change the main session tempo. This would be easy to repeat as you move on to the next section to be edited. I've been doing this when editing a slew of guitar files that are marked with various tempos. When your done, you can consolidate the edits individually and give each clip an identifiable name. Then drag & drop the newly edited files from the clip bin underneath the original copied track where it belongs. You can line up each edited clip with the original at the exact start of each clip. First, select the clip on the original track. Then press the Start key (Windows) or Control key (Mac) when selecting the related clip on the track below. The clip below will automatically snap to the same start position as the one above it according to the original time code. Just some ideas. I'm sure someone on here can provide more expert advice on how to carry out the task more efficiently. Or I'm completely missing the mark and not fully understanding the session objectives.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 02-25-2023 at 07:53 PM. |
Sub-beat markers not promoting when ctrl+click them in Beat Detective | GOOOTOOO | Pro Tools 2020 | 0 | 03-10-2021 06:28 AM |
Grid won't conform to identify beat markers in PT10 | LizS | Pro Tools 10 | 4 | 06-25-2014 09:51 AM |
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! | Robbry | Pro Tools M-Powered (Win) | 0 | 02-24-2010 02:14 PM |
what do grid lines do after beat detective bar-beat markers | cc1 | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 09:34 AM |
Beat Detective, Beat markers to Tempo Ruler?!? | phobia | Tips & Tricks | 3 | 01-01-2007 01:31 PM |
