Old 02-08-2023, 06:04 PM
NateAlexander NateAlexander is offline
Default Regex in 2022.12 VERY Broken
What the hell AVID!
Something is very wrong with the Regex in 2022.12, all my presets for renaming stems and midi from arrangers are dead in the water and even just trying to do it on the fly doesn't work.
searching for a string is now totally not accurate to the exact string
this regex to remove all extra spaces in one shot is totally broken
^\s|\s+(?!\S)|
Did they change the delimiter? Is it just... broken?
Old 02-14-2023, 02:47 PM
AudioWMC AudioWMC is offline
Default Re: Regex in 2022.12 VERY Broken
Having similar issues. I wonder how many people are really using regex in ProTools.
Old 02-15-2023, 08:07 AM
Ha! I would venture not many - I've been using PT since forever and regex off and on over the years, and I never even knew PT supported regex - just looked in the manual and lo and behold there's a whole section on it! Thanks for pointing it out! Now I wanna incorporate it into my workflow, but...if it's broken I guess I won't bother.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-15-2023, 08:29 AM
daeron80 daeron80 is offline
Never heard of it. Interesting.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-15-2023, 12:08 PM
i'm honestly about to roll back a version because I use it so often (ingesting stems from other writers and trying to conform them without a working batch track rename is... tedious).
It's honestly super handy, if you learn it well enough you can make a renaming task that would take many moves happen at once.
Old 02-16-2023, 10:05 AM
1m1 1m1 is offline
I urge you to submit a support case, precisely because not a lot of people are using Regex. I submitted mine and they couldn't reproduce it yet, they've requested that I send them my ptx file which I'll do when I get back to town next week.
Old 02-16-2023, 04:01 PM
moogboy100 moogboy100 is offline
Originally Posted by NateAlexander View Post
What the hell AVID!
^\s|\s+(?!\S)|
I don't think your Regex should have that trailing Pipe character. It's suffering from an infinite match loop. Try
Code:
^\s|\s+(?!\S)
I've tested some of my saved Regex patterns and they have been working for me in 2022.12. It's possible AVID strengthened their Regex pattern engine rather than broke it. Test your Regex patterns here and make sure they work.
https://www.regextester.com
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
Old 02-21-2023, 12:32 PM
Some of what I use is still working, but mainly I'm upset about case conversion.
Find: (\w)
Replace: \L$1
It doesn't work in the regex tester you linked, but I have no clue why.
It seems like there's different types of regex, and I don't know which one PT is using.
Old 02-21-2023, 01:09 PM
I will follow up by saying my regex still works in the tester linked in the PT reference guide...
Old 02-23-2023, 08:25 AM
It seems Pro Tools uses either the Javascript/ECMAscript or Python compatible version of Reg Expressions
Switch that site's Regex engine over to javascript/ECMAscript and it won't work. C++ is what I'm going to assume PT is written in, and that language uses the ECMAScript regex engine.
AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9 anearforgear Pro Tools 20 01-31-2024 12:06 PM
Regex in 2022.12 VERY Broken NateAlexander Pro Tools 1 02-09-2023 01:03 AM
MTRX Studio with Protools 2022.10 broken Jonne Pro Tools | MTRX & MTRX Studio 6 11-06-2022 01:34 PM
2022.9 and Waves broken devs1980 Pro Tools 41 10-22-2022 01:47 PM
Duy plugins gui broken in 2022.9 ejsongs Pro Tools 1 10-03-2022 12:39 AM
