Old 12-03-2008, 07:30 PM
Furn Furn is offline
Default Pro Tools won't launch (unexpectedly quit)
Today, my Pro Tools app wouldn't launch.
It worked well for 9 months.
I tried deleting the prefs, databases, etc.
I tried deleting the app and re-installing without success.
My setup:
MacBook
OSX 10.4.11
2 Gb RAM
MBox Micro
PT 7.4 (tried 7.4cs8, no luck)
Here's the start of the Apple problem report:
OS Version: 10.4.11 (Build 8S2167)
Report Version: 4
Command: Pro Tools LE
Path: /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE
Parent: WindowServer [95]
Version: 7.4 (7.4f309)
PID: 354
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
Thread 0 Crashed:
0 com.apple.CoreFoundation 0x9080dfa7 CFRelease + 56
1 ...gn.framework.CoreFoundation 0x02427368 I18N_Utils::GetCurrentLanguage() + 466
2 com.digidesign.ProToolsLE 0x00f26778 start + 15875356
3 com.digidesign.ProToolsLE 0x00002b5e start + 258
4 com.digidesign.ProToolsLE 0x00002a85 start + 41
Thanks for your help!
Old 12-03-2008, 08:32 PM
Craig F Craig F is offline
Default Re: Pro Tools won't launch (unexpectedly quit)
10.4.11 was installed or you had Software updater do it?
Did you try clearing the PRAM?
Thank you,
Craig
Old 12-03-2008, 09:08 PM
I think 10.4.9 was installed when I bought the machine... so I updated.
But that was long before I bought my MBox Micro.
Resetting PRAM didn't do the trick (good idea though).
Thanks for your time!
Phil
Montreal
Old 12-03-2008, 10:29 PM
the dude's Avatar
the dude the dude is offline
try removing any third party plugins ( except for the mixer )
and see if that helps
also try a new admin user
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 12-04-2008, 11:32 AM
JakeLloyd JakeLloyd is offline
I've been having a vaguely similar problem and was wondering if anyone could offer a solution.
I have a Macbook 2.4GHz Intel Core 2 Duo (Mac OS X 10.5.5), and am trying to run my Mbox 1 with Pro Tools LE 6.7.
However, whenever I open Pro Tools a box pops up and reads "Digidesign hardware is in use by another application (-1133)". Even if the Mbox isn't plugged in to the macbook, this sign still comes up.
I assume I need to download a driver but can't seem to find the right one on the digidesign website.
Can anyone offer any help?
Old 12-04-2008, 11:37 AM
DigiTechSupt's Avatar
Yes, you need Pro Tools 7.4.2 or higher for compatibility with OS 10.5.5. Do a clean uninstall of 6.7 before upgrading. You can purchase the upgrade in Digistore.
Avid Audio Tech Support
Support FAQ
Old 12-04-2008, 11:39 AM
Did you uninstall Pro Tools, or just delete the application? If you just deleted it, that won't do much good.
There are a couple different ways to uninstall:
1. Run the installer for the version of Pro Tools you're trying to uninstall - when you get to the Custom Install page, click on Custom Install and select 'Uninstall'. When you continue with the uninstall, it will give you the option for 'Clean' or 'Safe' - choose 'clean'.
2. In your Pro Tools Utilities folder you may have a Pro Tools Uninstaller - double click and follow on-screen instructions. Again, you'll be given the choice of clean or safe uninstalls.
3. On most Pro Tools install CD's or DVD's there will be an Uninstall utility - same steps as in #2.
Support FAQ
Old 12-04-2008, 08:00 PM
I did uninstall Pro Tools with the included uninstaller.
Making a new Admin user did the trick... I was able to start Pro Tools.
What's the next step to make it work on my 'main' admin user?
Thanks for your help.
At least, I can get back to work.
Phil
Montreal
Old 12-05-2008, 09:26 AM
THAT is going to be a tough one to answer, as there could be any number of issues with your main admin account causing the problem.
The error you originally posted:
Seems to point to some kind of language preference corruption. Obviously I can only speculate on this, as the log doesn't give much else to go on. Now which preference, specifically is corrupted - impossible to know without trial and error testing and that can become very tedious.
Sorry I don't have much else for you to go on - this is why we strongly recommend always having backups of your OS and other drives, so you have something to revert to should anything go wrong.
Support FAQ
ProTools 9 Crashes at launch (Quit Unexpectedly) ChrisStever Pro Tools 9 4 09-17-2012 03:19 AM
pro tools unexpectedly quit. hellbert macOS 1 07-06-2012 09:27 AM
Pro Tools won't launch - 'Pro Tools LE quit unexpectedly' joey141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-11-2009 03:18 PM
Cannot launch ProTools 6.9.2 - "Quit Unexpectedly" Mix One 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-04-2007 05:26 AM
HELP "ProTools LE Has Unexpectedly Quit" on Launch NHSD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-24-2006 11:57 AM
