ADC Total Weirdness.
I have measured the H/W insert delay that my converters and outboards are producing.
This is exactly 121 samples and in a a 96KHZ this is exactly 121 / 96000 * 1000 = 1,260416666666667 MS rounded that brings me to 1.26 Milliseconds. Now according to the digi manual this value is what I am supposed to enter in the H/W insert delay field... So that is what I do..... Here comes the weird part. When inserting the I/O in the insert of an audio track - 121 samples of delay is NOT applied to that track. Instead PT applies 205 Samples - which are 2.14 MS in 96 KHZ session..... What is up with that.... If anyone can explain this to me - I'm buying a cappuccino. Thanks
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
Re: ADC Total Weirdness.
I Think I may have found the BUG....
I have four Rosetta 800 interfaces connected to my core card via daisy chain thus I have 32 I/O's Channel 1-8 get 205 samples applied to then when entering the 1.26 Milliseconds value Channel 9-16 get 133 samples applied to then when entering the 1.26 Milliseconds value Channel 17-24 get 05 samples applied to then when entering the 1.26 Milliseconds value Channel 25-32 get 133 samples applied to then when entering the 1.26 Milliseconds value Now I dont know if this is an Apogee issue or PT's.... However it may be - this is an important bug in either of them - I will contact Apogee about this... In the meantime it would be cool if someone else could test this Thank 25
Seems this problem is NOT only with Apogee interfaces...
I downloaded the X-HD Firmware update and it changed the values I reported earlier - in the right direction only NOT the correct values... So I tried it with digidesigns 192 digi i/o - it is reporting WRONG values - even after firmware update... It is easy to reproduce: 1 - Open a session and set it to 96 KHZ 2 - Go to I/O Setup and select the H/W Delay pane. 3 - Enter the Value of 1 (One) Millisecond for the desired I/O Delay. 4 - Insert the I/O on an audio track 5 - PT will compensate the digital 192 I/O with 205 samples It should only compensate with 96 samples - as 1 millisecond at 96KHZ is equal to 96 Samples... Is this a BUG - or am I loosing it... Thanks for replies
Also consider that the ADC engine is compensating for the delay incurred in both the D/A and A/D converters. Don't input any manual delay compensation value and you should see an ADC value equal to the total value you saw minus the manual value that you put in.
Now here's where the fun for you begins. The Rosetta does not have conversion values identical to a 192. If you really want to compensate precisely, you're going to have to figure out the difference in delay between the 192 and Rosetta and take that into consideration when you enter the manual compensation value. Otherwise, your tracks with hardware inserts are not really going to be compensated properly.
I thought with the latest firmware the Apogee interfaces don't have the latency issues that they used to? Has anyone done any tests to confirm this..
The firmware update allows X-HD carded interfaces to be seen by Pro Tools as 192 Digital interfaces. This means that all 16 channels have identical delays rather than 1-8 and 9-16 having different delays when it appeared as a 192 interface. Even so, Apogee interfaces have longer conversion delays when compared to both the 192 and the 192 digital. This means that any hardware insert through an Apogee interface has to have an additional amount of manual compensation entered to compensate for the additional conversion delay. Don't ask me the values, I never actually documented them when I measured. Our workflow doesn't require knowing these values since all the mixing outputs are through Apogee interfaces and external summing. We just make sure all the drum tracks are out the DA-16s without any on the Rosetta since there is even a delay difference between those two different interfaces. Drum tracks shared across the two fall out of proper phase relationship.
One interesting thing to note is that now when I do an all digital bounce via my Rosetta 800 with ADC on and the option for compensate for input delays checked- the stereo mix comes back sample accurate with the multitrack- which makes me happy... |
The reason Apogee publishes the manual compensation numbers is so that you can put them into the H/W Insert Delay Compensation window to compensate for the additional delay of the Apogee converters. But this only applies to using the Apogee I/O for hardware inserts. Any way you cut it, if you use the Apogees while overdubbing, the tracks you record will always be slightly behind where they should be, unless you come up with a workaround. The worst is little more than a millisecond, but in this day and age, precision should be something expected. Should Apogee redesign their converters to have identical delay to a 192, or should Digidesign allow Pro Tools to play nice with third party interfaces?
Total I/O Possible with OMNI? | Tim R. | Pro Tools HDX & HD Native Systems (Mac) | 12 | 05-31-2013 11:23 AM |
HD 192 how many inputs in total | 2fly | Pro Tools TDM Systems (Mac) | 2 | 06-09-2008 02:26 PM |
NOW I'M IN TOTAL HELL!!! PLEASE HELP!! | schizo | Pro Tools TDM Systems (Mac) | 16 | 05-09-2003 11:07 AM |
Sorry am total new in all this and need a little help please | socata | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-17-2002 05:47 PM |
Pane total no PT LE 531 | danilo davila | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 10-04-2002 05:40 AM |
