Old 02-22-2008, 12:18 PM
agus agus is offline
Default plug ins won\'t load dae error 7054
Just updated ProTools 6.4.1 using the CS4 update. Now my plugins won't load. I get the dae error 7054. It first asks me to authorize the plug in. When I select Authorize, it crashes the program. ANY HELP? Go back to Pt 6.4.1 without the CS4 update?
Old 02-22-2008, 12:37 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: plug ins won\'t load dae error 7054
Which plugin/s? are they ilok authorized or disk authorized plugs?
Have you gone through the troubleshooting thread...
http://duc.digidesign.com/showflat.p...fpart=1#177661
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-22-2008, 04:40 PM
the dude's Avatar
the dude the dude is offline
6.4.1 has very specific versions that you must install
installing the latest versions will give you that error
you have to install the versions that are like 10 versions back
if you have the PT 6.4 installer disk I would suggest you get the plugins from there
there used to be a link on the archive support page that had download links for 6.4.1
but I cant seem to find it anymore
FYI even if the plugin says for version 6 and above 6.4.1 used completely different versions for MOST plugins
try this link
http://archive.digidesign.com/suppor...X_Plug-ins.pdf
or
http://www.digidesign.com/index.cfm?...&categoryid=36
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
PT 8 MIDI problems-- Xpand2 plug-in gets error #7054 refae Virtual Instruments 4 09-03-2009 03:05 PM
PT8: BFD Lite: Error 7054: Missing MSVCR70.dll: Plug-in Stopped Functioning mbrink Virtual Instruments 4 08-15-2009 08:38 AM
error 7204 when trying to load stereo plug in dekype Pro Tools TDM Systems (Mac) 1 12-12-2006 11:39 AM
PT 7.2 plug-ins deactivated and DAE Error 7054 beggehorn Pro Tools TDM Systems (Win) 12 08-22-2006 11:52 AM
DAE error #7054 - Plug in not made active? OneMadSon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 07:49 PM
