Old 02-03-2024, 05:42 PM
audiogamble audiogamble is offline
Default Import Session Data Bugs - 2023.12.1
2 new bugs I've uncovered from working in 2023.12 using "Import Session Data". Still present in the .1 hotfix . Have noticed this on several different computer systems I've worked on.
1. I used to be able to click and drag on the tracks list to select / unselect a number of tracks to be imported. I can still do this, but I'd say about 60% of the time what happens is that everything previously selected displays as unselected when my mouse click is in the down state. This doesn't actually deselect anything, because those tracks show as selected again after lifting my mouse back up. This simply makes it difficult to work in that window because I can't tell what's selected for import while clicking and dragging my mouse.
2. 2nd, and probably more critical bug, is something I've discovered when doing a source/destination import from one track to another. Any time I import from and to a track with a mapped physical output assigned on both the source and destination, this seems to create a double-mapping in the I/o window. It literally maps to that output twice, causing increased volume coming from that output. In the mix window, you'll see the little "+" icon showing it's double mapped. This can really throw you off if you don't notice it right away. The workaround is to go into the io window after an import, and fix the double mappings. The weirdest thing about this one is that I don't actually need to be importing output assignments. I just experienced this on a session where I was importing track colours only.
I can confirm that neither of these behaviours occurred on previous versions of pro tools.
Pro tools 2023.12.1
MacBook Pro M1Max - 10 core, 64gb ram
Ventura 13.6.3
Old 02-03-2024, 07:12 PM
DontLetMeDrown DontLetMeDrown is offline
Default Re: Import Session Data Bugs - 2023.12.1
One annoying thing I'm seeing is when I import a track's settings, I'll choose to not bring the audio, but when the track loads in the progress bar appears to show it loading audio files in. No audio files are imported, but the fake loading bar makes the process take longer than normal. This is on Windows 11, Intel i9 10900K.
Old 02-06-2024, 07:51 AM
tope d's Avatar
tope d tope d is offline
Pro tools 2023.12.1
Ventura 13.6.3
There is an on going bug on this. Let me create a support case for you so yours can also be tracked.
(Case 04753504)
Thank you
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-06-2024, 07:58 AM
Appreciate it. Thank you!
Old 02-06-2024, 02:20 PM
1m1 1m1 is offline
I'm seeing the same double mapping behaviour in 2023.12.1 as audiogamble. Also, the import process takes about 2 minutes when in 2023.6 the same import only takes about a second... it goes thru an "Updating I/O" series of messages being displayed even when I was only importing the Group property. It's unusable for a film session with many cues and union musicians on the clock.
Old 02-21-2024, 03:34 PM
...Any time I import from and to a track with a mapped physical output assigned on both the source and destination, this seems to create a double-mapping in the I/o window. It literally maps to that output twice, causing increased volume coming from that output. In the mix window, you'll see the little "+" icon showing it's double mapped. This can really throw you off if you don't notice it right away. The workaround is to go into the io window after an import, and fix the double mappings. The weirdest thing about this one is that I don't actually need to be importing output assignments. I just experienced this on a session where I was importing track colours only....
I can confirm same behavior here - in my case importing *only* main volume settings set I/O to the double mapping.
http://www.richbreen.com
Old 02-21-2024, 05:35 PM
sleiweke sleiweke is offline
Bug number 2 was happening for me in the previous version (2023.12) as well.
sleiweke
2019 Mac Pro Rack 3.3 GHz 12-Core 96 GB RAM
OS12.6.3
HDX Pro Tools 2023.6
Lynx Aurora (n) 32
2 Avid S1's
Old 02-23-2024, 09:07 AM
And...just did it again *only* importing groups.
Old 03-08-2024, 07:45 AM
moogboy100 moogboy100 is offline
Is this fixed in 2024.3?
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
Bug PT 2023.12: Import Session Data -> Atmos Trim and Downmix crustn Pro Tools 3 01-23-2024 08:22 AM
PT 2023.6 AAF import Bug Ken Skoglund Post - Surround - Video 3 10-30-2023 09:39 AM
2023.9 Import audio from file mpierluissi Pro Tools 3 10-20-2023 10:20 AM
Two Annoying Import Session Data Bugs therecordinghouse macOS 2 03-12-2013 05:04 PM
More 7.2cs2 Import Session Data bugs.. ilovemyssl Pro Tools TDM Systems (Mac) 0 04-18-2007 05:28 AM
